C4 Help Needed
cobras281
Ok, I have a C4 fully rollerized, servo billet cover, 3000 stall converter anti balooning plates etc etc. Full manual reverse valve body and a trans brake.
3000lb supercharged mustang notchback. runs 11.3s off soft launch on footbrake. 450rwhp
1. launched off foot brake car ran fine through all gears
2. Next round launched off transbrake no problem went through 1st gear fine, went to slap second and it was like I missed a shift in a stick car, threw it to 3rd and again no gear. Got to end of the track and towed back to pit.
3. no fluid visible undercar, no case cracks etc etc. started it up no 1st, 2nd, or 3rd foward. It inches foward barely i mena barely. Put it in reverse works fine. Engage transbrake it doesnt lock in, it automatically goes in reverse.
4. Got it on the lift dropped pan fuild is good not burnt, no meatal shavings in pan, linkage moves fine.
5. Dropped valve body no visible cracks, not too sure what i was looking at above that that is where i suck at trannys, there is a band looking thing in the middle possibly looks snapped off on the one side? like a mounting tab or something I have a pic dont know how to post it though.
ANY IDEAS??? you can email me for the pic or sho wme how to post here.
[email protected]
Make for sure that the shifter is adjusted perfectly. I've seen transmissions burn themselves up on 1 pass due to misadjusted shifters. Even if 1-2-3 are the only gears that line up on the shifter. A broken intermediate band would explain no second gear. If the band broke chances are 1 or both band struts would be in the pan or on top of the valve body. Forward clutches are applied in all forward ranges. If they're smoked or don't apply it won't move forward. The fact that when you hit the transbrake it goes in reverse makes me think direct clutches are smoked or not being applied. Hope this gives some direction. Let me know what you find out.
