C4 hesitation
  • Thread starter Thread starter 66moneypit
  • Start date Start date May 4, 2005
66moneypit
536
Northern Va
May 4, 2005
  • May 4, 2005
I have a C4 transmission in my 66 and it's been sitting for a while since my car is getting rebuilt. Took the car for a test drive and it seems to be hesitating coming out of second gear as you accelerate. Like I said...it's been sitting a while at least 3 years. Any advice on how to proceed ?
krash kendall
1,258
Aldergrove, B.C. Canada
May 4, 2005
  • May 4, 2005
Check the vacuum line going to the modulator for leaks, or the modulator itself for problems.
F
ForceFed70
That's why they call it "dope"
4,818
BC Canada
May 4, 2005
  • May 4, 2005
What exactly do you mean by "hesitating"?
FasterThenU72
108
Orange County, CA
May 7, 2005
  • May 7, 2005
do you mean that it wont shift or it holds it for a while before it shifts? Or when your at full throttle, it wont shift until you pull your foot off the gas....whats going on....
66moneypit
536
Northern Va
May 7, 2005
  • May 7, 2005
Took it around the neighborhood and it won't shift out of first gear AT ALL. I can accelerate, I can take my foot off of it and it won't go into another gear. It's pretty frustrating because that's the only part of the restoration that hasn't been touched. Any ideas ?
84convertablegt
589
Columbus, OH
May 8, 2005
  • May 8, 2005
i had all kinds of weird problems with my old c4 before i got a new one. the biggest problem was mating a 40 year old tranny to a brand new engine. but what it turned out to be was the pump drive on the tranny had broke off completely.
R
Ronstang
1,294
Houston Texas
May 8, 2005
  • May 8, 2005
Sounds like your governor is stuck.
66moneypit
536
Northern Va
May 8, 2005
  • May 8, 2005
What's the best way to test that ?
Alarus
226
Az
May 8, 2005
  • May 8, 2005
A governor on a 66?!?! i thought that came out with the EFI too give it a "top speed"
Max Power
1,774
St Paul
May 8, 2005
#10
  • May 8, 2005
  • #10
Uh...no.
The governer in your automatic is how your tranny senses vehicle speed. Automatics have had em since about the time they were invented.
Not the same type of governer you are thinking of.
Alarus
226
Az
May 9, 2005
#11
  • May 9, 2005
  • #11
oh ok thx for the history lesson (still kinda new one the older cars thing, im only 17)
FasterThenU72
108
Orange County, CA
May 9, 2005
#12
  • May 9, 2005
  • #12
dont trip bro, i'm only 20 and been doing the "car thing" for only like a year and half.... , I like to think i know plenty, but it never hurts to learn something new even if you took a crack at it and you were wrong, thats how you learn.....remember we were all in the same boat as you at one time
R
ravenblack67
46
#13
  • May 9, 2005
  • #13
Make sure you have vacuum from the manifold to the transmission modulator. The modulator is on the passenger side at the rear. If you have good vacuum, the problem is internal and can several different things. I've been rebuilding the C4 for many years. Your best bet is to find a guru living near you. Locate the nearest mustang club and ask for help. Good luck.
Max Power
1,774
St Paul
May 9, 2005
#14
  • May 9, 2005
  • #14
No worries! The newer cars do have top speed that are limited, for a lack of better term, governers. These usually work through the computer to limit fuel and/or spark at high speeds to limit how fast the car can go. These also existed to some extent back to the late 60s with cars like the Boss 302, which had an electronic rev limiter to keep people from blowing their motors up. I think Ford installed it to reduce warranty claims more than out of any concern for safety.
Back on topic, I would replace the modulator, check vacuum to it, flush and replace fluid completely and go throight the service procedure for adjusting the bands. If that doesn't fix it, out it comes.
P
Engine Mysterious coolant leak at back of engine
  • palerider94
  • Jan 18, 2026
Fox 5.0 Mustang Tech Jan 19, 2026
AeroCoupe
J
Low RPM jerking
  • Justinkins
  • Jul 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 11, 2026
fasterthangas
F
1965 289 xmission
  • sctang
  • Nov 15, 2025
1965 - 1973 Classic Mustangs -General/Talk- Nov 30, 2025
Mcmahst
3.08 gears with a manual trans
  • limp
  • Aug 27, 2026
  • 2 3
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 14, 2026
Qtrhrse23
A
Engine 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Today at 7:51 AM
AlexM556
A
