c4 pan install
  • Thread starter Thread starter 65notch
  • Start date Start date Oct 24, 2005
65notch
303
661 Cali
Oct 24, 2005
  • Oct 24, 2005
i installed a new pan on my c4. and i have leaks around the pan. looks to be from between pan and gasket. i used a rubber gasket AND rtv. was the rtv a bad idea and the tranny fluid can get through it?
rbohm
6,698
550
204
tucson,az
Oct 24, 2005
  • Oct 24, 2005
atf has far more cleaning agents in it than engine oil does, but that shouldnt have cauesd any problems. it sounds like you might have overtightened the pan bolts. even with a rubber gasket and rtv you can damage the gasket to the point it wont seal if they are overtightened. when you replace the gasket again, dont use the rtv, and just tighten the pan bolts untill the gasket starts to just bulge. also check the pan and make sure the gasket surface is clean and level with no high spots around the bolt holes.
J
JB66
565
New York
Oct 24, 2005
  • Oct 24, 2005
I agree. Either use one or the other. The RTV makes the rubber so slippery that it will squeeze out where ever it can and it will leak. RTV is used to replace many gaskets in the new vehicles. If you are going to use the rubber gasket, you can put some spots of adhesive on the pan to hold it in place for installation. DON'T overtorque the pan bolts!
krash kendall
1,258
Aldergrove, B.C. Canada
Oct 24, 2005
  • Oct 24, 2005
I usually put a thick bead of RTV on the pan then finger tighten it. After about 20 min. I snug it up. I put a cork gasket on a turbo 350 once and over tightened it. It split at every bolt. Been using RTV ever since.
302 coupe
1,952
Macon, Ga.
Oct 24, 2005
  • Oct 24, 2005
I use aluminum pans and a cork gasket, install it dry,torque to 10 ft-lbs, never a drop of leakage. Sheetmetal pans always leak.
10secgoal
2,801
San Diego
Oct 24, 2005
  • Oct 24, 2005
Yep, got tired of it and put in the aluminum with a thick flange. No leaks so far. The metal pans get dimples in them from use ove the years. So when you tightend, all that touchs is dimple to gasket.
A
Engine 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Today at 7:48 PM
AlexM556
A
P
Engine Mysterious coolant leak at back of engine
  • palerider94
  • Jan 18, 2026
Fox 5.0 Mustang Tech Jan 19, 2026
AeroCoupe
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
R
1965 C4 Tranny leaking?
  • Rick1965Coupe
  • Jul 28, 2024
Classic Mustang Specific Tech Aug 7, 2024
Rick1965Coupe
R
97 GT with 03 explorer Eddie Bauer edition 4.6l
  • basbill73
  • May 10, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 11, 2026
squeak93
