C4 question
  • Thread starter Thread starter DukeGnarley
  • Start date Start date May 4, 2006
DukeGnarley
597
Auburn/Ellensburg, Wa
May 4, 2006
  • May 4, 2006
I'm at the point where i'm starting to think about engines. how much torque can an old stock c4 handle? If the answer is "not much" then i'm probbly going to have to put off the engine until i get that taken care of.
washMO66
1,000
Washington, MO
May 4, 2006
  • May 4, 2006
Old stock C-4, not much is probably accurate. If your just spinning not too wide tires it will last ahwile. If your thinking of sticky tires and real power it will frag.
I built from the rear forward, the motor was the last part of my equation.
Rear end, suspension, drive shaft, tranny then motor.......
Cobain03
996
Lexington, Ky
May 5, 2006
  • May 5, 2006
duke... your car is beautiful!
i think my c4 is about to crap. i cannt shift it manually. it jerks real hard going from first to second so i just leave it in drive.
my mods are in my sig if you want to compare your plans with mine
J
jeff69becky
14
  • May 5, 2006
it really depends on how much power your talking and the condition of the trans. I have a 69 faskback and I droped a roller cam H.O out of an 88 gt in it Ford E303 cam, eld. rpm manifold, port-polished intake and matching heads,1.6 roller rockers, and a 670cfm holley carb Id say a mild motor. The tranny is a c4 with a rebuild kit forward and reverse pack. its the cheapest way to go and that would hold up 350hp easy. If you do go and blow it up its not like they are all that rare..junkyard!
J
jeff69becky
14
  • May 5, 2006
http://www.bulkpart.com/Merchant2/merchant.mvc?Screen=CTGY&Store_Code=2&Category_Code=Ford
heres a link for all your automatic needs
NasaGT
1,993
Virginia
May 5, 2006
  • May 5, 2006
Nice link! Thanks!
D
danny clemens
728
  • May 5, 2006
A C4 can be built to take a lot of punishment.
thehueypilot
1,084
Medina,Tennessee
May 5, 2006
  • May 5, 2006
True except the earlier versions don't have much in heavy duty parts available. The 70 and up have all the good parts.
DukeGnarley
597
May 5, 2006
  • May 5, 2006
Thanks! but really, it doesn't look so great in person (the paint is terrible).
well my plan was to either get a 347, a 351, or a 408. and i don't really want to put any money into an automatic. i was just hoping i could get the engine and make the c4 last until i'd have the money for a tko, but from the sound of it, it looks like i'll be getting the tko first.
J
jeff69becky
14
#10
  • May 5, 2006
  • #10
Thats because pre 70 they used .788 24 spline input shaft and in 70 they used a .839" 26 which was the HD of C4 which was later changed after post 70 to a 26spline on the converter and the converter end had a 24 spline. Ive acually been looking for a 82-up C5 which is more efficent or so they called the newly redesigned C4 which had a locking converter, diff. valve body ,and bell housing which can be swaped out with C4 Componets to make a pretty HD tranny, now your looking at supporting up to 450 hp stock and with a hardened input shaft you can run more ponies to the rear wheels.
D
D.Hearne
11,730
south louisiana
May 5, 2006
#11
  • May 5, 2006
  • #11
This'll give you an idea. My dad bought a 69 E330 Chateau Club Wagon new in 69. It was in the family for a tad more than 10 years. Motor was a 2 bbl 302. Rearend was a Dana 60 with 3.73 gears. In those 10 + years we put over 100,000 miles on it. We also had the heavy duty C-4 it came with rebuilt 5 times.
3.08 gears with a manual trans
  • limp
  • Aug 27, 2026
  • 2 3
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 14, 2026
Qtrhrse23
Electrical/engine bay harness questions
  • djj62478
  • May 29, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 6, 2026
djj62478
P
Engine Mysterious coolant leak at back of engine
  • palerider94
  • Jan 18, 2026
Fox 5.0 Mustang Tech Jan 19, 2026
AeroCoupe
A
Resolved 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Nov 1, 2026
manicmechanic007
J
can you use the heads off a H O 302 to put on a regular 302 engine
  • Jan H
  • Feb 25, 2026
  • Other Auto Tech
Other Auto Tech May 17, 2026
nickyb
