c4 to t5 conversion
  • Thread starter Thread starter 1967stang302
  • Start date Start date May 2, 2005
First Prev 2 of 2
garner67
68
SF Bay area
Jun 25, 2009
#21
  • Jun 25, 2009
  • #21
+1 for ModernDriveline. Well thought out and engineered parts and outstanding customer service.
However, if you're really strapped for cash, you'll do better scavenging parts from a junk yard.
2+2GT
3,333
10
79
Southeastern Pennsylvania
Jun 25, 2009
#22
  • Jun 25, 2009
  • #22
Sadly, it depends where you are. Around here, 15, even 10 years ago, there were maybe 10 yards with old enough cars for such things, within 30 minutes drive of here. Now there's one.
G
GNGREN
144
Carroll Valley, PA
Jun 25, 2009
#23
  • Jun 25, 2009
  • #23
Am I the only one that noticed this thread is over 4 years old ?
P
phutch11
328
Jun 25, 2009
#24
  • Jun 25, 2009
  • #24
Even though the post is 4 years old I want to make sure that anyone searching for information in the future on this swap knows that you MUST use the original yolk from the T5.
As any transmission is used the yolk and tail shaft bearing wear together and must be used toghether from then on. If you take a used T5 and throw in any yolk but the original one, you will have leakage and vibration issues.
Ask me how I know...
For those that will flame me, go over to Mustang Forums and search for a thread by "Gun Jam" called Pinion or driveline angle.
He has the dreaded post T5 swap vibration issue, just like I do, and guess what solved it after trying everything else...a new tail shaft bearing and new yolk.
Posted via Mobile Device
2+2GT
3,333
10
79
Jun 25, 2009
#25
  • Jun 25, 2009
  • #25
I agree that if your slip yoke is a worn-out, rusty POS it should be replaced. However, despite what many parts suppliers say, there is no such thing as a "T5 conversion slip yoke". The T5 uses the exact same 28 spline pattern with the same outside diameter as any 3.03 3-speed, C4 automatic, or 28 spline 4-speed transmission. There is nothing special about the T5 slip yoke.
No matter what trans you have, if you have the slip yoke out for any reason, and it's not in perfect shape, replace it. It's not like they're hard to find, new.
When replacing the slip yoke, you're doing it because it's worn or corroded, usually both. It is essential that you replace not only the seal, but the slip yoke bushing, too. As with the slip yoke, the 3.03 3-speed, C4 automatic, 28 spline 4-speed use the same seal and bushing. They are cheap, at most $25 for the set, so don't be stingy for a few bucks. Fortunately, with the right tools, this can be done in the car, in less than two hours. If your mechanic wants to charge more than two hours, and claims the trans has to come out or apart, find a more competent mechanic.
P
phutch11
328
Jun 26, 2009
#26
  • Jun 26, 2009
  • #26
2+2GT - how do you do it with the tranny in the car? I had heard that at a minimum you had to pull the tail shaft housing.
Can it be done w/o pulling the housing?
2+2GT
3,333
10
79
Jun 26, 2009
#27
  • Jun 26, 2009
  • #27
Sure- once you get the drive shaft and slip yoke off and remove the seal, you insert a special tool, which is cylindrical with tabs that hook outward onto the bushing. Then you tighten the center screw in the tool, and the bushing slides right out. The installation tool is even easier, you just start the bushing in, slide the tool onto the bushing, and tap it the rest of the way in. At some point, usually when you remove the seal, the oil will start drooling out, so be ready if this happens.
First Prev 2 of 2
K
3.8 T5 & Bellhousing to 1987 Lincoln 5.0
  • ks65stang
  • Mar 2, 2026
  • Other Auto Tech
Other Auto Tech Mar 3, 2026
D
For Sale 1993 Mustang LX for parts or restore
  • diesel farmer
  • Oct 6, 2026
Fox Body Mustangs For Sale (1979-93) Oct 6, 2026
diesel farmer
D
T5 5th gear 89 gt
  • mac_55
  • Mar 19, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 20, 2026
Mustang5L5
D
Yet another v8 swap
  • dulcimerbob
  • Sep 19, 2026
  • 4 5 6
2K
1974 - 1978 Mustang II Talk & Tech Yesterday at 6:39 PM
dulcimerbob
D
87 lx 4cyl to v8 project 4 lug disc conversion questions
  • 87lx428
  • Mar 24, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 25, 2026
87lx428
