C4 tranny
  • Thread starter Thread starter ScreamingMimi
  • Start date Start date Sep 6, 2004
ScreamingMimi
54
  • Sep 6, 2004
Hi - doing the much bally-hooed I6 to V8 swap in a Sprint 66 Mustang - no problems till i got to the bellhousing/flexplate. Had a 133 tooth flexplate - swapping to the 164 tooth. found out belatedly that the transmission shaft is the smaller of the two - it wobbles when inserted into the torque converter. I am having difficulties finding the right torque converter since i would like to avoid switching trannies since the one i have is in prime shape - any ideas?
T
TOM B
20+ Year Stangneter
Nov 15, 2002
872
Harrisburg Pa
Sep 6, 2004
  • Sep 6, 2004
THE SMALL SHAFT C4 IS 24 SPLINE. you should run the 157 tooth flywheel with 10.5 bolt pattern. I dont think the larger 164 tooth will fit into a small c4 bell. Both TCI and B&M make good converters but I would go with a TCI for more of a selection for the 24 spline 10.5 pattern. I run a 24 spline shaft with a Tci 3000 stall converter on a TCI 157 tooth performance flex plate.
65straightsick
411
Montgomery, AL
Sep 6, 2004
  • Sep 6, 2004
Or go for the T-5
ScreamingMimi
54
  • Sep 7, 2004
I have the larger bell already - I just want to use my smaller spline with the 164 since it is the flexplate that was originally matched to my 302 that I am dropping in. Worst case scenario - I replace the tranny - I thought about the T5 but I am on a doozy of a budget. And around here, classic mustangs and parts are HARD to come by unless you order out of a catalog and that takes more $ than I have to fork over. By the way - will the 302 manage with the 157 flexplate or do I have to stay with the 164 for strength?
1966 Sprint Mustang (no more!)
302 out of 71 Torino
One woman restomod!!!!
T
TOM B
20+ Year Stangneter
Nov 15, 2002
872
Harrisburg Pa
Sep 7, 2004
  • Sep 7, 2004
Im running about 450hp through my setup with no problems. I have the small shaft and a tci 157 tooth flex, 3000 stall converter. more teeth dont make the flex stronger, just buy one thats for racing, there cheep too.
ScreamingMimi
54
  • Sep 8, 2004
GREAT! I will go back to square one and find a 157 with torque converter - much easier than swapping the entire tranny - i can use the same bellhousing and everything should bolt up nice and tight - THANK YOU!
K
3.8 T5 & Bellhousing to 1987 Lincoln 5.0
  • ks65stang
  • Mar 2, 2026
  • Other Auto Tech
Other Auto Tech Mar 3, 2026
C
C4 To 5spd Swap In A 66 L6
  • Caveman49
  • Feb 18, 2018
Classic Mustang Specific Tech Feb 21, 2018
rbohm
Drivetrain C4 Conversion Problem
  • hopson
  • Oct 23, 2013
3K
Fox 5.0 Mustang Tech Oct 29, 2013
84Ttop
N
flexplate issues
  • nfarthing03
  • Sep 16, 2010
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Sep 16, 2010
nfarthing03
N
C
Starter problem
  • carloslopez99
  • Apr 27, 2010
Classic Mustang Specific Tech Apr 30, 2010
Tim65GT
