C4 Trans advise
  • Thread starter Thread starter DUVAGA
  • Start date Start date Dec 30, 2006
DUVAGA
  • Dec 30, 2006
I have a C4 in the '67. Previous owner gave me the invoice from the rebuild he had done just before it was parked, 4 years later I bought it from a barn.
I've probably put less than 1k miles on it, car has started slipping out of 2nd gear, mostly when hitting humps at intersections and only after it's warmed up. It has an aftermarket oil cooler only, does not go to the radiator. It acts like it's starving for fluid, but it's full. When I replaced the filter, I found plastic pieces from the speedo gear in the pan (speedo had locked up twisting the cable and shredding the gear).
I'm thinking of adding some brake fluid or over the counter additive to flush it out then replacing filter/fluid again, hoping that I've just got debris plugging stuff up.
Any advise on what else to try before pulling it out and rebuilding?
Do band adjustments require the pan be removed?
Thanks.
P
palerider94
573
  • Dec 30, 2006
Best advice get a shop manual - lot of information on band adjustments - see ebay about 50 bucks fuol set.
DUVAGA
  • Dec 30, 2006
Thanks, good advise. I found an old Chilton guide to auto transmisiions I'd forgotten about, so I got the intermediate band adjusted to specs. Torque to 10lbs, back off 1-3/4 turns, torque locknut to 30 lb. Also lists several options for troubleshooting 2nd gear slipping: vacuum modulator or intermediate servo are my next steps if this didn't help.
C
C4 trans help needed
  • CPH89LX
  • Apr 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 28, 2026
CPH89LX
C
A
Resolved 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Nov 1, 2026
manicmechanic007
Drivetrain 83’ Glx convertible C5 Trans help!
  • JacksonJared2113
  • Dec 25, 2025
Fox 5.0 Mustang Tech Dec 26, 2025
JacksonJared2113
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
C
Trans issues.
  • ChrisCruz1972
  • Aug 13, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 8, 2026
slow84lx
