c4 trans install snag
  • Thread starter Thread starter TeamEntity
  • Start date Start date Apr 7, 2010
T
TeamEntity
130
  • Apr 7, 2010
have you guys used anything. i was thinking wide masking tape to hold the torque convertor at bay while installing the trans. dayum thing keeps just popping out enough that it will not seat again fully on the pump which is keeping me from bolting this pig back on. i'm off by a half and inch thats it. has happend to me three times now. I was thinking since everything is lined up i could have someone push on the trans. aka tailshaft while i spin over the engine and the tc should fully seat again and so will the bellhousing. Any tips? thanks.
woodsnake
1,353
15
69
Hicksville, NY
Apr 7, 2010
  • Apr 7, 2010
When the torque converter is properly seated, it will sit inside the bell and have ~1.5~ inches gap. Meaning, it will sit fully on the pump shaft, and you will have a solid inch and a half gap or so...
If you are lifting the trans straight up into the bay, and the TC is falling out, then you aren't on squarely.
Make sure that the TC bolts are lined up with the holes on the flexplate!
T
TeamEntity
130
  • Apr 8, 2010
thank god your advice is free lol. i'm getting a trans jack tomorrow to make life a bit more easy and making some guide pins to aid in installation for alignment. I'm going to do the tape thing. since the tc just comes off the first set of splines mostly due to moving it back for adjustment after the studs make there way through the flexplate.
E
Finished my Fox Hydroboost Install - Tips
  • Engineer Duane
  • Apr 9, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 5, 2025
Engineer Duane
E
Progress Thread Dirty Water Racing 89 Notch Project
  • ShedBuiltMS
  • Sep 29, 2020
  • 2 3 4
14K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 28, 2021
Flyboy60
F
Upgrading Dash Bulbs to LED
  • kiddiccarus
  • Jan 6, 2019
2K
1996 - 2004 SN95 Mustang -General/Talk- Jan 6, 2019
kiddiccarus
Timing Cover/harmonic Balancer Removal And Replacement
  • jrichker
  • May 28, 2017
16K
Fox 5.0 Mustang Tech Jul 6, 2024
What I Did For Thanksgiving.
  • CarMichael Angelo
  • Nov 29, 2014
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Dec 2, 2014
