C4 Transmission -- I think I screwed the pouch
Takt
48
Madison, WI
I have a 66 Mustang with a 302, 2.8 open gears and a C4 Transmisison. I had/have what I thought is a small leak of tranny fluid. I drove the car about 75 miles and it did fine. When I got home, I checked the fluid -- and it was bone dry. I filled it back up, but couldn't go for a drive until I needed to go on a 30 mile drive.
I got on the interstate and the car wouldn't drop into 3rd. I was running 65 mph at 3,800 rpm. It ran like this for about 10 minutes, then it dropped hard into 3rd. After I stopped, I had to drive another 20 miles at 55mph and it never dropped into 3rd.
Any chance I didn't completely screw the transmission? I'm pretty sure I know the answer, but I'm hoping....
Second -- if I'm screwed, what are my options? Should I have it rebuilt, or should I buy new, or... ?!?
Thanks, and damn it :)
That is a ford safeguard kind of thing. When your clutches are gone in third, it won't shift past second. I have gotten them so hot, that it wouldn't shift past first. The nice thing is you can drive it to get repaired.
As long as the case is ok you can put all new internals in it. Why was the trans leaking in the first place ? Was it the pan gasket or something else ?
If you have some cash to put into a project I would definately sugest going to an AOD. The overdrive gear is very nice to have. The only part you would have to have made custom would be the drive shaft (or modify your stock one). The shift linkage conversion from PA trans worked great on my buddies Cougar and the Ron Morris cross member went in perfectly. The shift linkage would be very easy to fabricate yourself.
I think it was leaking at one of the hose connections (to run the fluid to cool it). I didn't get that far :)
AOD -- you are speaking greek to me. What is entailed on making that conversion? I'm not worried about the drive shaft or anything, but not sure what you are talking about.
Thanks,
AOD = Automatic OverDrive
If you drive a lot of highway miles it is a good option, but once you start adding too much HP it quickly becomes an 'expensive' tranny to race w/. But, keep it w/in reason and you're OK IMO.
Takt said:
So we're talking about going away from the C4 to a different transmission. Or is there an "add-on" that gives the C4 an overdrive?
If a different transmission, which one?
Thanks
There is not an add on to the C4; it only has three forward gears.
The AOD IS the different transmission; 4 speed auto. The OD will help on the highway and while cruising; the RPM's will drop due to the tranny OD gearing.
As for fitament, maybe someone more educated can chime in... I'd imagine the tranny and a few other aftermarket parts would make it a fairly simple project.
You can add and overdrive to a C4 with a Gear Vendors overdrive.
Home.
http://www.gearvendors.com/
Ford overdrive.
http://www.gearvendors.com/hrford3s.html
I already mentioned what parts were needed to do the swap in my last post. If you have an AOD rebuilt, they are very stout and can take a lot of daily abuse. They definately are NOT drag race trans. You can drag race them now and again but they wont stand up to costant racing. They will survive a rough daily drive but draging puts a lot of stress on that thing. A C4 is far superior and much cheaper to build for drag.
What are you going to be doing with this car ?
I am not a fan of the AODE, you need to add a transmission control unit to the car if you use one of those and they are more expensive trannys all the way around. They use mercon V fluid which is more expensive, they cost more to have work done on and the filters are like 60 bux each. All that and they shift like CRAP even after a shift kit is put in one. I know, I've got a late model with an AODE in it and the thing shifts slower then molassis in January.
