Today I'm replacing the oil in my transmission... it's very brown. So, I remove the pan, then I remove the filter... and there sitting on the filter is a spring! It's about 1.25" long, and about 1/4" in diameter... What do you think this is?
Then, I'm using a Haynes Ford Transmission overhaul book for instructions, and it says to lower the torque converter bolt to drain the torque converter. I've got a C4 and 302... but I don't see where this drain plug is... the instructions say to remove the torque converter cover plate, but I don't even see that! Can you help me?
Thanks!
<<my daughter wanted to make sure I added that!
Thanks!
