C4 vs. AOD
  • Thread starter Thread starter foxmustangman
  • Start date Start date Nov 7, 2007
foxmustangman
196
Idaho
Nov 7, 2007
  • Nov 7, 2007
So my AOD is screwed (has been for a while...dont have 4th gear) and i was going to go in this week and get quotes on it when i saw a c4 in the newspaper for $300..
Does the C4 have any advantages over an AOD, or is an AOD better than a c4?
thanks
Darkwriter77
Resident Ranting Negative Nancy
5 Year Member
Jul 1, 2005
315
283
134
Apache Junction, AZ
Nov 7, 2007
  • Nov 7, 2007
An AOD is basically a C4 with an extra gear for fuel economy/cruising. They're both just about as durable, although some will consider the C4 a tad more reliable because it doesn't have an OD gear to destroy (because people like to jam into OD at WOT and burn up the OD band). As such, the C4 would probably be cheaper and easier to rebuild later on, if needed.
Personally I'd just opt for a nicely-built AOD over a C4, myself. Is this a DD we're talking about, or strictly a weekend warrior/track beast? If it's a DD and you do any kind of highway driving, you'll definitely be missing that OD gear on long drives ... especially if you're running any kind of gears (like 4.10's).
RYC CUKR
1,437
Orlando
Nov 7, 2007
  • Nov 7, 2007
The C4 is lighter, since it doesn't have all the OD servos and bands, and IIRC it has less parasitic loss than an AOD. And the C4 can be a tough trans for not too much money.
You are pretty much in the same boat as I am with my 93. Smoked the OD band a while back. I went back and forth between a C4 and an AOD. I ended up deciding that I liked having OD especially with the 4.10s and I was driving the car on the interstate fairly regularly. So if it is primarily a track car then a C4 should be fine but if you need to drive it long distances or at 65 or higher for any length of time then I would go with another AOD.
foxmustangman
196
Idaho
Nov 7, 2007
  • Nov 7, 2007
Well, I dont travel that much so...plus any 4th gear is better than driving around in 3rd all the time.
with a C4, can you shift into 1st,2nd,3rd,4th...'cuz the AOD goes 1,D,OD
i dont have any rear-end gears (unless the previous owners put one in, and i dont think they did), so i think a C4 will work.
Anybody else?
foxmustangman
196
Idaho
Nov 7, 2007
  • Nov 7, 2007
FORD C-4 Automatic Transmission, complete w/bell housing, torque converter, flex plate, all linkage & inspection cover. Operates geat. $300 obo. 465-0887 or 866-7281.
Darkwriter77
5 Year Member
Jul 1, 2005
315
283
134
Apache Junction, AZ
Nov 7, 2007
  • Nov 7, 2007
FYI, there is no 4th gear with a C4. Only three - no overdrive.
C4 = P-R-N-D-2-1.
AOD = P-R-N-(D)-D-1.
foxmustangman
196
Idaho
Nov 7, 2007
  • Nov 7, 2007
oh...i feel dumb.
(should be called a C3!!!)
81elky350
at home
Nov 7, 2007
  • Nov 7, 2007
Here's an idea, take the tranny out of the Nissan, it's a 4-speed!
black87ttop
43
burlington,new jersey
Nov 8, 2007
  • Nov 8, 2007
Hey if your gonna go c4 you might as well just keep the aod, with the burnt up overdrive, that will save you 300 bucks and give you a c4 lol. i had too
D
DREAMZOFHIRPM
40
BROOOOOOOKLYNN
Nov 8, 2007
#10
  • Nov 8, 2007
  • #10
if your looking to make power and a good aod call Lentech... but i would definitly stay aod,, not being able to cruise on highway sux, need that O/D
B&m hammer shifter c4 question
  • 387lx
  • Mar 18, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 19, 2026
387lx
3.08 gears with a manual trans
  • limp
  • Aug 27, 2026
  • 2 3
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 14, 2026
Qtrhrse23
C
C4 trans help needed
  • CPH89LX
  • Apr 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 28, 2026
CPH89LX
C
D
For Sale 1993 Mustang LX for parts or restore
  • diesel farmer
  • Oct 6, 2026
Fox Body Mustangs For Sale (1979-93) Oct 6, 2026
diesel farmer
D
W
Speedometer and shifting issues
  • wyatt-tetro891
  • Aug 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 18, 2026
wyatt-tetro891
W
