C4 with Lokar shifter
lokar shifter
According to Lokar's web site, the shifter comes with one switch that can be used for reverse lights or for neutral safety. If you bought the indicator boot it comes with both switches, but cost as much as the shifter did. Hope this helps.
reverse
65fastbackresto was right when he said that the neutral safety switch and backup light switch were on the transmission for C4 and C6. I have an FMX which has the switch in the shifter. Unless you had to remove the switch on the transmission to install the shifter or the stock switch is malfunctioning, then you should be able to use the stock switch. The new Lokar catalog had Ford indicator boot CINB-1754 and CINB-1753 on page 11. Jamisson42166, you have a great looking engine bay.
