c6 leaking BAD?
  • Thread starter Thread starter ericnhu
  • Start date Start date Sep 26, 2011
E
ericnhu
  • Sep 26, 2011
just picked up a 69 stang.
302=306 with a C6
Trans leaks in lower drive gears pretty bad, but reverse will pretty much empty a full trans in seconds!
My guess was pump, but wanted to see what you guys think it could be?
This is the start to a long project, so I will be here often.
eric
1967project
89
Oklahoma
Sep 26, 2011
  • Sep 26, 2011
Since you didnt say where it was leaking from, I will go out on a limb here and throw out what comes to mind.
First check to make sure the 17 pan bolts are there. If so they may have been over-tightened and caused your pan to flex. Or not tightened at all. (should be 10-14 ftlbs torque if not mistaken)
Second check the shifter shaft, there should be a seal on it.
Third check the O-ring at the end of the shaft. During a re-build the wrong size can be put back in.
Other areas for leaks are the pump o-ring, front seal near the bellhousing, rear seal by driveshaft,
E
ericnhu
  • Sep 26, 2011
updated info
looks like its from the front pump area. pan is tight and flush... no sign of leaks from shifter input, tailshaft seal has tiny leak.
I looked under the car as it was cycled thru the gears. Dumped about 4 qts trans fluid in 30 seconds in reverse (powerbrake to load without tire spin)
The best guess I have is the pump, but just wanted to know, due to the different volume of leaking in different gears, could it be a valvebody issue or something else?
I'll be visiting this forum often and will have pics up soon.
A
Engine 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Monday at 4:43 AM
manicmechanic007
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
J
Bad Vibration
  • jefffletch47
  • Feb 12, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jun 2, 2026
dgrinnan
D
Fox Xtremely high fuel consumption
  • PonyGTrider
  • Apr 11, 2026
  • 9 10 11
5K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 9, 2026
PonyGTrider
O
8.8 Pinion Nut Leak
  • OX1
  • Jan 3, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 5, 2026
OX1
O
