c6 shifting strange !!
  • Thread starter Thread starter rbjb99
  • Start date Start date Aug 27, 2009
R
rbjb99
  • Aug 27, 2009
Hi, I'm new to the site and am hoping someone can help me.
I have a 73 351c c6 all stock, just finished rebuilding the car and when I drive the car if I put it straight into drive and go, it wont shift until the car is screaming up the road, if i put the car in 1st then move it up to drive it changes up and down perfectly all day long.
I don't have to shift it manually, just down into 1st then up to drive and its ok.
If i stop and put it in park then straight down to drive it will shift weird again.
Anyone had this problem?? I thought it may be the modulator but why does it shift right one way and not the other???
Thanks for any help.
Rod
stonecoldtx
214
Dallas, TX
Aug 27, 2009
  • Aug 27, 2009
Rod
What exactly did "rebuilding the car" encompass? Did you do any work on the transmission?
D
D.Hearne
11,730
south louisiana
Aug 27, 2009
  • Aug 27, 2009
Go to your local Advance Auto Parts. There in the transmission additives shelf you'll find a bottle of Lucas Transmission Treatment. Buy a bottle and pour it into the C-6. Problem solved after about two laps around the block.
R
rbjb99
  • Aug 28, 2009
will give it a try, thanks for the help
D
D.Hearne
11,730
south louisiana
Aug 29, 2009
  • Aug 29, 2009
It's probably gummed up from sitting too much. That stuff cleans the gum off the valve body parts. I've used it in an E4OD that was acting up and a 62,000 mile C-6 that was 38 years old (and never rebuilt) It worked on both transmissions. The C-6 was doing the same thing yours was.
W
Speedometer and shifting issues
  • wyatt-tetro891
  • Aug 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 18, 2026
wyatt-tetro891
W
Ford truck engine swap issues
  • keel
  • Jul 7, 2026
  • Other Auto Tech
Other Auto Tech Jul 13, 2026
General karthief
Drivetrain Broken clutch cable- what it looks like
  • JulianR
  • Aug 6, 2026
Fox 5.0 Mustang Tech Aug 10, 2026
gkomo
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
C
For Sale Mint 1993 Calypso 5.0 Convertible
  • Chrispy62
  • Aug 22, 2026
Fox Body Mustangs For Sale (1979-93) Aug 22, 2026
Chrispy62
C
