Progress Thread C6AF F 6A F 4bbl Autolite
Steel Ride Mustangs
Tomball, TX
Hi All
I have a 66 GT Coupe 289 4bbl. It came with a new Holley but wanted to replace with a 4BBl Autolite.
I have a clean 4bbl C6AF F that has 6A F stamped on the side... 1.08 v
Would this be a good carb to run on a 289 stock block??
Looks it was made for the 390/428.
Is it too much?? I thought 1.08ven would be good...
Thoughts/advise... really appreciate!
  • Sponsors(?)
Realmongo
I prefer to be called "Evil Genius"
2,310
40
99
Western Mass
The non-HiPo 289 4V engines came with a 1.08 carburetor, which is rated for 480 CFM. Your C6AF-F was used on 390 with automatic transmission.
Thread starter Similar threads Forum Replies Date
S Progress Thread 4bbl Carb For '66 Gt 289 1965 - 1973 Classic Mustangs -General/Talk- 5
T Fuel Swapping From 2bbl To 4bbl 1974 - 1978 Mustang II Talk & Tech 3
Hammering Fox 85 Gt 4bbl Not Kicking In! 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 2
CarMichael Angelo If Having A 4bbl Carb Makes You A Hillbilly,........ 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 85
7 1971-73 Mustang, 4BBl Cleaveland factory O.E.M. exhaust manifolds for sale Exhaust 0
warrenbh Is there a carb better than a Holley 4bbl? Classic Mustang Specific Tech 17
Red 4bbl 2.3L 2.3L (N/A & Turbo) Tech 5
R 66 Mustang 289 4BBl Carb Classic Mustang Specific Tech 1
G Ford Newbie - Intake gasket - '68 289 4bbl Classic Mustang Specific Tech 11
Edster I've read some buzz on stock 4bbl carbs. Classic Mustang Specific Tech 14
L 4bbl on a 289? Classic Mustang Specific Tech 11
Y 67 Mustang 4bbl conversion Classic Mustang Specific Tech 9
M What carburetor and intake should i choose when switching from a 2bbl to a 4bbl? Classic Mustang Specific Tech 5
5 4bbl vaccum vs mechanical secondary, what does it mean? Fox 5.0 Mustang Tech 3
65fastback2+2 AOD with 4bbl Classic Mustang Specific Tech 18
Cobain03 2 bbl to 4bbl Classic Mustang Specific Tech 44
U 2bbl to 4bbl conversion Classic Mustang Specific Tech 0
Apsychotic Factory Emissions Config. on '75 Mach 1-302-4bbl. 1974 - 1978 Mustang II Talk & Tech 5
BlackVert Power Plus Typhoon 4bbl Intake 1994 - 1995 Specific Tech 1
M what cam & 4bbl intake are you guys using? Fox 5.0 Mustang Tech 3
1 4BBL quench heads came today. Classic Mustang Specific Tech 2
allcarfan webers, vic jr, 4bbl carb? engine possibilities...HELP ME OUT Classic Mustang Specific Tech 15
1 Anyone use this for their 351c 4bbl? Classic Mustang Specific Tech 1
1 351c 4bbl open chambered heads any good? Classic Mustang Specific Tech 11
68GEETEE 2bbl head on 4bbl engine question Classic Mustang Specific Tech 11
V Autolite 4100 Secondary Diaphragm Lever replacement 1965 - 1973 Classic Mustangs -General/Talk- 2
T Plugs - NGK or Autolite? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 10
M Autolite 1100 1965 - 1973 Classic Mustangs -General/Talk- 4
Sweetmarie66 2100 Autolite Carb Classic Mustang Specific Tech 8
M Autolite 4100 Trouble 1965 - 1973 Classic Mustangs -General/Talk- 2
Steve491 Expired Autolite Ht1 Plugs, Oil Filters, And Fuel Filter Engine and Power Adder 0
billison Had To Get Autolite 2546 For A 88. 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 18
Nick Bos 1970 Mustang 302-2v Carb? Classic Mustang Specific Tech 1
sen2two Autolite 25 Plugs 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 8
THEUNDERCOATER Gap For Autolite 25 Fox 5.0 Mustang Tech 5
A Need Autolite 4100 Help Asap.. 1965 - 1973 Classic Mustangs -General/Talk- 1
R Expired Rare Autolite 4 Barrel In Line Carburertor Engine and Power Adder 0
M Autolite 4100 Secondaries Driving Me Nuts 1965 - 1973 Classic Mustangs -General/Talk- 5
skiwesser11 Questions About Autolite Spark Plugs Fox 5.0 Mustang Tech 2
cptawesome 66 I6 Autolite 1100 Install Won't Start The Welcome Wagon 4
Davidx9x Expired Autolites Ht1, Valve/tb Covers, Towr Brace, Cams, Gears, Steeda Ud Pulleys, Tails, Saleen Axleback Engine and Power Adder 1
65-Fstbk Autolite 4100 1.08 Vs 1.12 Classic Mustang Specific Tech 4
ZachMartin68 SOLD Autolite 4100 4 Barrel Carburetor VERY lightly used!!! Engine and Power Adder 4
B Any difference in Motorcraft SP498 and Autolite AP5143 spark plugs? 2005 - 2014 Specific V6 Tech 1
phendyr Options For Salvaging An Autolite 2100 Carburetor Classic Mustang Specific Tech 3
E Autolite Battery Cover - Need Battery Rec Classic Mustang Specific Tech 0
O Flooded Autolite 1100??? Classic Mustang Specific Tech 11
BlackVert Autolite 4100 troubleshooting Classic Mustang Specific Tech 3
Dougsters For Sale Autolite 2100 1.23 Vent. 354 CFM Engine and Power Adder 1
Dougsters Rebuilt my Autolite 2100 but have a float level question ? Classic Mustang Specific Tech 4
