  • SN95 4.6L Mustang Tech
Digital Tuning Cai And Throttle Body Swap
  • Thread starter Thread starter 03Cavillo
  • Start date Start date Dec 1, 2014
03Cavillo
stl.
Dec 1, 2014
  • Dec 1, 2014
03 mustang gt. Put bbk .78mm throttle body plenum one piece and cold air intake. Said would work with factory setting now idling off and is a whistle when throttled normal coming from throttle body.?
Mattstang04
1,152
144
104
St. Louis, MO
Dec 1, 2014
  • Dec 1, 2014
Depending on the sound, it may be a vacuum leak. Spray a little brake cleaner around the plenum and intake. If the motor revs up, that is where your vacuum leak is.
03Cavillo
stl.
Dec 2, 2014
  • Dec 2, 2014
But there are ones that have that whist
Thanks will try.
03Cavillo
stl.
Dec 2, 2014
  • Dec 2, 2014
Will try tonight. Thanks.
03Cavillo
stl.
Dec 2, 2014
  • Dec 2, 2014
Tried no vacuum leak. Bought sct tuner.
DIYdudeguy
27
Earth
Dec 7, 2014
  • Dec 7, 2014
Some whistle or sucking noise is normal with a CAI. When I installed my CAI it would make a slight whistling sound on moderate acceleration (sounds like when you try to whistle while inhaling), after installing a tb and plenum it became more of an audible "shoop" noise, which is normal. My idle seemed like it was out of whack as well right after installing the tb and plenum, but as long as your IAC is working right, the idle should be adjusted back to normal.
Mattstang04
1,152
144
104
St. Louis, MO
Dec 7, 2014
  • Dec 7, 2014
You could try disconnecting the battery to reset the computer. Then let the computer relearn with the new parts. Sometimes TB swaps need to be adjusted for in the computer.
03Cavillo
stl.
Dec 7, 2014
  • Dec 7, 2014
Went to American muscle bought a tuner for my mods. Hopefully will improve.
wmburns
SN Certified Technician
Aug 14, 2009
5,892
514
204
Houston Texas
Dec 8, 2014
  • Dec 8, 2014
Did you follow the manufacturer's recommended procedure regarding HOW to set the idle stop screw?
Here's some more information on how to trouble shoot Idle/IAC issues.
http://www.stangnet.com/mustang-forums/resources/troubleshoot-iac-idle-problems-1996-2004.13/
TeamCaffeineGT
193
15
18
Springfield, MO
Dec 8, 2014
#10
  • Dec 8, 2014
  • #10
Mine also made a lot of air noise as well as a high pitched dog whistle sound. I thought it sounded cool enough to not really ever care about why.
J
Engine 4.6 Running rough at half throttle
  • jake411
  • Aug 3, 2026
SN95 4.6L Mustang Tech Aug 4, 2026
jake411
J
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
Throttle body
  • ShredThePred
  • Nov 1, 2024
SN95 4.6L Mustang Tech Nov 2, 2024
89ripper
A
Blow through intercooled questions
  • AngryH58
  • Aug 31, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 1, 2026
AngryH58
A
M
94 Mustang gt throttle body
  • Mike3
  • Jul 26, 2025
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Sep 2, 2025
revhead347
