  • 1994 - 1995 Specific Tech
cai
  • Thread starter Thread starter TBCOBRA88
  • Start date Start date Nov 25, 2009
TBCOBRA88
26
South Carolina
Nov 25, 2009
  • Nov 25, 2009
Well, i had got my surging idle fixed and now another problem.. dont know how much more of this i can take. Added my UPR cai and when i rev it up it backfires like crazy.
302GTS
If you need herpes, I'm your man!
Apr 20, 2009
481
Largo, FL
Nov 25, 2009
  • Nov 25, 2009
First check and see if your MAF is plugged in properly. See if it's even working by plugging and unplugging it, and noticing any changes that occur in the way the car runs. Anything you unplugged to put in the intake, make sure it's plugged back in.
toyman
1,944
54
79
Vernon BC
Nov 26, 2009
  • Nov 26, 2009
Agreed. There is nothing related to the CAI which would cause the problem other than something not being connected properly.
302GTS
Apr 20, 2009
481
Largo, FL
Nov 26, 2009
  • Nov 26, 2009
Been there done that. I've left things disconnected before and flipped out, only to realize that it was my own mistake in the long run.
OP, check out the MAF first and foremost and report back. Also, if the MAF is plugged in and working properly, pull codes and check in with us again. The guys here are real helpful, and the majority have much more knowledge that I can offer. Just remember we're coming up on a holiday weekend so site traffic might be low.
HISSIN50
34
129
Nov 26, 2009
  • Nov 26, 2009
Also: If the CAI has an oilable air-filter element, see if the MAF wires got covered in oil. This is not uncommon.
Good luck.
blksn955.o
3,263
st.louis mo 314
Nov 26, 2009
  • Nov 26, 2009
Is everything tight and sealed correctly with the clamps? I had an issue with the rubber connector coming loose and air was getting into things after the MAF causing backfires and stuff.
Did you by chance mess with the timing/remove the spout connector when you installed the new CAI? I would check to make sure you did not pull anything loose or pull any wires out when you removed the stock airbox setup.
LethalInjection
217
Arkansas
Nov 30, 2009
  • Nov 30, 2009
Make sure the rubber vaccuum hose that runs from the cai tube to the valve cover is connected. Also check the connection of the cai itself at the joints. It sounds like you have a lean condition likely caused by unmetered air.
Foxbody high rpms and surging rpms
  • 86foxseth
  • Jun 9, 2026
Fox 5.0 Mustang Tech Jun 13, 2026
G
Idle surging after warm up
  • GALLY3309
  • Jun 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 10, 2026
K
Resolved Need some assistance. Holley Terminator X alongside H/C/I. Very rough/inconsistent idle
  • karhoot
  • Jun 6, 2026
Fox 5.0 Mustang Tech Jun 6, 2026
karhoot
K
M
93 5.0 Microsquirt with Stage 3 trickflow tuning issues
  • marxpreston11
  • Jun 22, 2026
  • Digital Self-tuning Forum
  • 2 3 4
2K
Digital Self-tuning Forum Sep 16, 2026
Qtrhrse23
T
Engine Need help figuring out misfire and backfire
  • trystancounts
  • Sep 25, 2025
Fox 5.0 Mustang Tech Sep 26, 2025
