Cal/Edit
Guero
2,148
When i save a MAF curve and try to open it on a different tune its all messed up. The highest volt is like 1.90 but when I saved it, it was fine. It only with the ones I saved, all others ones that were installed when cal/edit was installed are fine. And all my currently saved tunes are fine also. Whats the problem?
When working with the maf curve it has been found best to hand load
your values ;)
Then after saving them ... Check A L L of them again :Word:
The import/export thing can hose up big time :bang:
so
Just don't trust those methods :nono:
Also ... don't be surprised if you see the values change a tiny bit
after you save then :eek:
Usually it will be very small like 1/4 to 3/4 of 1% :D
Grady
