Calculate compression
  • Thread starter Thread starter CochinoFilipino
  • Start date Start date Nov 30, 2004
CochinoFilipino
171
CA
Nov 30, 2004
  • Nov 30, 2004
Someone please help my figure out compression ratio.
If I have 9:1 with 64CC chamber heads and a .030 overbore on a roller 5.0 block, what would the compression be by switching to 61CC chamber heads?
Thanks,
D
D.Hearne
11,730
south louisiana
Nov 30, 2004
  • Nov 30, 2004
3cc MIGHT get you a 1/4 point increase
Route666
1,652
Brisbane, Australia
Nov 30, 2004
  • Nov 30, 2004
I get 9.3 assuming a 3" stroke.
EDIT: Here's how I arrived at that:
(4.03 / 2)^2 * Pi * 3 = cylinder swept volume = 8 times the combustion chamber volume (the 9 in 9:1 minus 1).
= 38.2667...
Divide by 8 to find out what combustion chamber volume is
-> 38.2667... / 8 = 4.783...
Multiply by 2.54^3 to convert to CC
-> 4.783... * 2.54^3 = 78.385...
Minus the 3CCs for change of head chamber = 75.385...
divide by 2.54^3 to get back to CI = 4.6002...
Add that to 38.2667... (the swept volume) = 42.866...
Divide that by the combustion chamber volume
-> 42.866... / 4.6002... = 9.318
therefore new CR ~ 9.3:1
D
D.Hearne
11,730
south louisiana
Nov 30, 2004
  • Nov 30, 2004
did the math, it'll get you 3 tenths increase. Not hardly worth the effort just for the compression increase.
D
D.Hearne
11,730
south louisiana
Nov 30, 2004
  • Nov 30, 2004
How'd you come up with 10.4 ? I get 9 to 1 with 64cc heads same as he said, and 9.3 with 61 cc. 627 cc cylinder swept volume, 61 cc head, 9.5 cc for the gasket, and 5cc for the piston volume , and that's assuming he's got a zero deck, which he most likely doesn't have, unless he has the right pistons and decked the block
F
Fostang
1,400
Stockton, Ca
Nov 30, 2004
  • Nov 30, 2004
Instead of trying to guess.
Find out what your deck height will be, what type of piston will be used + or - CC, head cc, type of gaskets that will be used etc.
Changes in the deck height or gaskets make for some huge differences if they are enough.
Route666
1,652
Brisbane, Australia
Nov 30, 2004
  • Nov 30, 2004
I edited my post, you don't need to know what deck height is, you can work out total combustion chamber volume by knowing that the 9 in 9:1 is going to be the swept volume. You can then modify the combustion chamber volume (take 3 off) to change to the 61cc heads chamber volume and add that to the swept volume, and divide by the combustion chamber volume to arrive at the ratio.
EDIT: Ok that's wrong - the 9 includes the combustion chamber as well. Well then you know the swept is 8 times the combustion chamber then. I'll change my result.
CochinoFilipino
171
CA
Nov 30, 2004
  • Nov 30, 2004
Thanks you guys are fast.
FYI, I'm not just trying to increase compression. I just found out the Aluminum GT40Y303 heads I have for my rebuild kinda suck. I thought they were very close to the X303 heads but they are not.
GT-40 Y's: Aluminum, 1.94 int./1.54 exh. 160cc intake runners. 53cc exh. runners. 64cc chamber
GT-40 X's: Aluminum, 1.94 int./1.54 exh. 178cc intake runner, 62cc exh. runner. 64 or 58cc chamber.
I was looking through the Ford Racing catalog and found that the Y-headed crate engine was rated at 315HP while the X-headed engine was rated at 340HP. Cam, compression etc was the same, just diferent heads.
http://www.fordracingparts.com/crateengine/302smallblock.asp
I was basically copying the the crate engine specs. So I was contemplating putting the Y303s on ebay and buying some TrickFlows which are 61CC.
I suppose I should see how much the machineshop wants to port the Y303's.
CochinoFilipino
171
CA
Nov 30, 2004
  • Nov 30, 2004
I was initially wondering about compression because I wanted to run regular crap gas.
Then I realized that more than compression will determine what gas I use (i.e cylinder pressure, timing etc).
Then I got to thinking about how more compression can make the engine more efficient.
Then I was wondering how the cost of using premium gas in a more efficient engine would weigh against a less efficient engine on regular.
Then thought forget it, get heads that perform the way I want and use whatever gas is required.
So expect a "what gas" thread once I figure out what I'm going to do about the head situation.
And thanks again, Now I can save that cool formula Route666 posted and figure it out for myself in the future.
F
Fostang
1,400
Stockton, Ca
Nov 30, 2004
#10
  • Nov 30, 2004
  • #10
Don't forget that aluminum heads will allow you to run pump gas with a little more timing/compression.
Route666
1,652
Brisbane, Australia
Dec 1, 2004
#11
  • Dec 1, 2004
  • #11
Filipino I still didn't change the 9 in my first post up there. You should take whatever your compression ratio is and minus one - THAT is the swept area (pi * r^2 * h)
I'll change it now, if you copied it, please make sure it's original CR - 1. EDIT: Or you'll balls up like I did.
D
D.Hearne
11,730
south louisiana
Dec 1, 2004
#12
  • Dec 1, 2004
  • #12
With a 9 to 1 compression range it should run on 87 octane. Might require more depending on how much timing you give it. My 10.4 to 1 331 stroker will run on 89 if I need it to, simply by backing the timing down.
CochinoFilipino
171
CA
Dec 1, 2004
#13
  • Dec 1, 2004
  • #13
I've never done any porting. Do you guys think opening up the runners on aluminum heads would be too big an undertaking for a beginner? I would stay away from the valve seats.
I'm wanted to portmatch everything anyway.(i.e. TB to intake manifold, upper to lower manifold, lower to head and head to eexhaust.) But I was not comtemplating going into the runners until now.
Thanks for the help with the brainstorming.
D
D.Hearne
11,730
south louisiana
Dec 1, 2004
#14
  • Dec 1, 2004
  • #14
What cam are you running? As for porting, I think you'd be better off leaving them be, except for port matching. With iron heads, that's a different story, there, you'd be working on a $50 set of heads, so if you screwed up, you'd not be out the cost of the aluminum heads. You could also mill the Y heads about .030-.040 to get the comp ratio up, that would add some power too, and that in addition to the port match could conceivably get your gain to what the X heads would.
66P51GT
721
Cerritos, CA
Dec 2, 2004
#15
  • Dec 2, 2004
  • #15
Here is a compression ratio calculator I created in Excel.
Enjoy.
CochinoFilipino
171
CA
Dec 2, 2004
#16
  • Dec 2, 2004
  • #16
I'm using Ford's E303 cam: Duration @.050; 220*/220*, Lift; .498"/.498". Like I said, I was basically copying their crate engine.
I'll be using an AOD with an aftermarket TQ converter (expect a "what stall?" thread) and either a shift kit or valve-body. And 3.50 gears in the rear.
And yeah, I think I won't touch the heads. I already have alot of work to do on this thing.
D
D.Hearne
11,730
south louisiana
Dec 2, 2004
#17
  • Dec 2, 2004
  • #17
You should be able to use a stock or near to stock stall with that cam. Don't get to radical or you'll forfit the whole purpose in using an AOD for the mileage increase. An E cam should be able to idle at less than 1000 rpm's in gear, so a stall for that purpose shouldn't be necessary. The idle on my 331 stroker with it's Z303 is surprisingly low, it idles ( this is with a 4 speed) at 6-700 rpms.
CochinoFilipino
171
CA
Dec 2, 2004
#18
  • Dec 2, 2004
  • #18
Cool. That'll save me a few ducats.
66P51GT, Thanks for the spreadsheet
N
Looking for ECU/CHIP for 1992 5.0
  • Nathan26
  • Sep 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 8, 2026
Qtrhrse23
H
Ongoing Battle With Hydraulic Lifters
  • hailer06
  • Jun 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 9, 2026
J
Engine 4.6 Running rough at half throttle
  • jake411
  • Aug 3, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 20, 2026
DangStitches
D
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
A
1987 5.0 speed density Foxbody crank no start
  • Alan2204
  • May 23, 2026
Fox 5.0 Mustang Tech May 30, 2026
Mcmahst
