Calibrating the MAF sensor?
02 Mineral Gray said:
Where do you get this done???
I was told I have to have the cars MAF recalibrated for the new intake. Is this true?
No you do not need to have it recalibrated for the new intake. Only if you changed injectors. And then the changes SHOULD be done in the eec through a tune, although most aftermarket MAF's will calibrate it to match injectors. This however is not the best way to do it, since it throws off the load scaling in the eec.
