calibrating the old speedometer
  • Thread starter Thread starter DukeGnarley
  • Start date Start date Jun 13, 2006
DukeGnarley
597
Auburn/Ellensburg, Wa
Jun 13, 2006
  • Jun 13, 2006
Alright, so I've upgraded gear ratios to a 3.55 and i need to get this speedometer reading properly.
i've been everywhere i can think of. transmission shops, parts stores, and even a couple of ford dealerships. the only thing i could find is a 20 tooth speedometer gear (my old one was an 18) for my C4. I installed it, knowing it wouldn't be right, but would probably be closer. My speedometer seems to read about 20% higher than the actual speed of the car. so, going off of that it would seem that i need a 24 tooth speedometer gear. I'm not sure where to find one, or if it will even fit.
So, does anyone know if a 24 tooth speedometer gear will fit in the stock C4? Where should i try to find one?
Any other suggestions?
R
Ronstang
1,294
Houston Texas
Jun 13, 2006
  • Jun 13, 2006
It think the white gear is 24 tooth and should be available from any Ford dealer but ones that handle FRPP would be your best bet.
66HertzClone
428
Central New Jersey
Jun 14, 2006
  • Jun 14, 2006
This one is close, http://store.summitracing.com/partdetail.asp?autofilter=1&part=TCI-881004&N=115&autoview=sku I made the same gear change as you did and used this gear, since there are so many teeth they end up being very thin and will wear out as a result. When I removed the gear as I installed the GV overdrive to my car, I notice the teeth were almost paprer thin, no dobt it would have failed in a very short time. I think it was in use for about 1K miles, not a very long life at all.
mudbilly
175
South County, Maryland
Jun 14, 2006
  • Jun 14, 2006
i have the same set up and i think that the best i could find was 22 i don't remember the exact count
anyway my speedo is 5 mph fast.......
DukeGnarley
597
Jun 14, 2006
  • Jun 14, 2006
Is anyone using a ratio adapter (little gear box thing)?
68RCodeConv
345
Houston, TX
Jun 14, 2006
  • Jun 14, 2006
Best you are going to find is a 23 tooth gear. Most Mustang vendors do NOT have them but Ford Motorsports sells them as well as some transmission places. As for the speedometer gear reducer, good luck. They only came on cars with 3.91 or 4.30 rears and are very hard to find and sell for big $$$$ when they show up on ebay. I've heard of aftermarket gear reducers but I have yet to see one that is a bolt-on deal. A 23 tooth should get you close. I have 3.89 rear gears and with a 23 tooth gear I'm only 5% fast.
Speedometer Calibration
  • Sonny Bibb
  • Sep 11, 2026
  • Digital Self-tuning Forum
Digital Self-tuning Forum Sep 13, 2026
Sonny Bibb
M
1996 GT Speedometer electrical nightmare
  • moon96gt
  • Oct 7, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 17, 2026
CAMTWO1070
T
Drivetrain Can’t identify correct speedometer gear
  • townethug
  • Jul 12, 2025
Fox 5.0 Mustang Tech Jul 21, 2025
FastDriver
W
Speedometer and shifting issues
  • wyatt-tetro891
  • Aug 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 18, 2026
wyatt-tetro891
W
D
96 get convertible-sell or part out?
  • DTCstang
  • May 17, 2026
  • What is it Worth?!?!?
What is it Worth?!?!? May 18, 2026
nickyb
