Caliper hiting disc brake
  • Thread starter Thread starter MavericK5L
  • Start date Start date May 8, 2004
M
MavericK5L
111
Montreal
May 8, 2004
  • May 8, 2004
Ok here how it goes.
Since I bought the car .. I can hear a noise comming from the front right wheel. I hear that sound everytime I hit a bump in the street.
By taking the wheel off and looking at the brake system .. I found out that the caliper is hiting badly on the disc brake.
I've change the caliper, disk. both bolt that hold the caliper. And I ended up having the same issue.
Caliper are not from FORD... and it does that on the passanger side only.
What else can I do ? . and please dont tell me do buy a bear brake kit or something like sa !
Thanks for your input !
88stangmangt
2,332
Stafford,VA
May 8, 2004
  • May 8, 2004
spindle bent maybe?
M
MavericK5L
111
Montreal
May 8, 2004
  • May 8, 2004
I will look into that but I doubt it !
Thanks 88stangmangt !!
T
TheUser
1,859
Springfield, MO
May 8, 2004
  • May 8, 2004
how is the caliper hitting the disc(rotor)? Which part is it hitting? If the caliper is bolted up and you have pads on there, I don't see how the caliper could ever touch the rotor? For what it's worth, I had a similar problem with my caliper bolt hitting my wheel; I solved that by getting a 1/4 inch spacer
Matt90GT
3,055
Oregon
May 8, 2004
  • May 8, 2004
Pretty simple. your caliper bushings are shot. install new ones or metal units sold by MM. Also get new caliper pins.
SuperStang83
1,693
Boyertown, Pa
May 8, 2004
  • May 8, 2004
Make sure it not the dust sheild either!
Jakob
M
MavericK5L
111
Montreal
May 9, 2004
  • May 9, 2004
with my bare hand I can duplicate the problem.
I just new to hold the caliper in my hand and I can move it up and down.. just a bit. like 5 milimeter or so.
the bottom is tightened but at the upper bolt .. there is the problem.
And I'm sure is something with that because the rotor grind all the inside of the caliper.
I thought it was a sleeve in the caliper or something that was loosen that's why I bought new one . but with all the new stuff its still doing the same exact thing ..
I'm thinking about bringing it to the Dealer to let them figure out what's wrong !
G
Auto City Classics 67-70 Mustang disc brake kit question/s
  • GOvert
  • Jun 30, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jun 30, 2026
GOvert
G
Brakes Brake caliper ID help
  • kidott
  • Sep 2, 2025
Fox 5.0 Mustang Tech Sep 2, 2025
AeroCoupe
87 lx 4cyl to v8 project 4 lug disc conversion questions
  • 87lx428
  • Mar 24, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 25, 2026
87lx428
Fox Another try for the European guy to get his first Fox
  • Schargedfox
  • Aug 3, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 4, 2026
DadLife0724
H
Strange steering/brake issue
  • Haxmaster
  • Jun 2, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Jun 3, 2026
squeak93
