Calling all tech wizards, here's a doozy....
  • Thread starter Thread starter DREDD_LX93
  • Start date Start date Mar 15, 2010
  • 3
First Prev 3 of 3
D
DonMaximo
217
Lewisville, Texas
Mar 26, 2010
#41
  • Mar 26, 2010
  • #41
OK... you have base timing set properly...
Keep your timing light on AFTER the SPOUT is reconnected.
You should now see timing advance beyond 10 degrees.
Have a friend or you and your 6' arms open the TB...we should see more advance.
Let us know what your observations are ???
For Shyts & Giggles... and forgive me for asking...have you disconnected battery for 15 minutes to clear KAM ??? There's never any harm in doing this...and I would suggest it before following the steps I suggested above.
It's Beer:30 here... catchya later
-D
D
DREDD_LX93
39
#42
  • Mar 27, 2010
  • #42
The timing does change once I put the SPOUT back on.
This time I cleared the codes by disconnecting the battery over 15 min.
But the lingering problem remains....
When I first turn it on, it starts fine and if I mash the pedal it revvs up just fine, but after about 15-20 min, with or without the SPOUT connected, it slowly begins to idle lower and lower, shaking violently, and if I mash the pedal it sounds like it slows down even further, until it finally just dies.
After that, I cannot turn it on anymore, I have to wait a long time to be able to do so.
What are these symptoms indicative of?
BlackGT89
774
Huntsville, AL
Mar 27, 2010
#43
  • Mar 27, 2010
  • #43
Without wading back through, I can't remember if you replaced the TFI module on the distributor or not. These units are known for warming up and then flaking out. Turn the car off and let it sit, the TFI (Ignition Module) will cool off and behave until it gets hot again, then flake out again. Might be a good prospect to be causing your problems. Just a thought...
D
DREDD_LX93
39
#44
  • Mar 27, 2010
  • #44
Could it be the IAC or the MAF?
D
DREDD_LX93
39
#45
  • Mar 27, 2010
  • #45
Well, it's a brand new MSD Pro Billet 5.0 Distributor, and it came with a TFI module. Although it's new, I wouldn't rule out that it might be damage (who knows how long they remain on the shelf at Summit warehouses).
I will say this, after it dies, the distributor is REALLY hot to the touch.
I'm gonna try a new one I had bought for the original distributor, see what happens.
D
DREDD_LX93
39
#46
  • Mar 27, 2010
  • #46
Something else, when the car first turns on, the fuel pressure is between 35-40 PSI, but right around the time that it shuts off, the fuel pressure is between 50-60 psi.
Is that too high? Am I getting a rich condition? All I've changed fuel-system wise is the fuel pump (255 lph) and a fuel pressure guage at the scrader valve. I haven't added an adjustable fuel-pressure regulator.
D
DREDD_LX93
39
#47
  • Mar 27, 2010
  • #47
I just found out something about open loop and closed loop.
It seems that while it's in open loop, it runs, but when it hits closed loop, is when it dies. Would would cause it to die once it hits closed loop?
TrophyHead
1,195
11
49
PA
Mar 28, 2010
#48
  • Mar 28, 2010
  • #48
Must be a bad engine sensor. Did you pull codes?
BlackGT89
774
Huntsville, AL
Mar 28, 2010
#49
  • Mar 28, 2010
  • #49
Sorry DREDD, I missed that you had the MSD Billet Dist. hence a new TFI. From what I've seen some folks swear by the MSD Dist. and some have had troubles. I still have my stocker so I can't say one way or the other.
Man, that fuel pressure seems way too high. Mine is about 30PSI at idle with the vacuum line on and jumps to about 39PSI with the line disconnected. Pull the vacuum line off of the FP regulator and make sure it isn't sucking gas in the line (ruptured diaphram). Have you pulled the codes yet ?
sharilewis
#50
  • Mar 29, 2010
  • #50
hiii
I'm curious, did the mechanic point the rotor to the #1 cylinder in the block? Or on the cap? What direction is the TFI pointing at?
Sealed Lead Acid Battery
40864Fairlane
#51
  • Feb 20, 2012
  • #51
What was the outcome of this? I know this is being brought back from the dead... I think I am having issues just like this too...
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Feb 21, 2012
#52
  • Feb 21, 2012
  • #52
Please start your own post: digging up old dead threads like this one just causes confusion and the date on it causes people not to post answers.
If you like, click on the link that goes directly to http://www.stangnet.com/mustang-for...-checklist-for-fuel-injected-mustangs.787471/, Cranks OK, but No Start Checklist for Fuel Injected Mustangs. It has everything you need to find and fix no start problems.
castine917
126
Wyoming, Mi.
Feb 21, 2012
#53
  • Feb 21, 2012
  • #53
People will post answers regardless of age of first or last post. This user searched the forum and found a thread with info in area they were looking. If user started a new thread someone would come in and say "use the search function".
As far as the outcome goes we may never know since DreddLx93 has not been active since march 30,2010.
40864Fairlane, that knowledge of when a user was last seen can be found by clicking on a users name in most forums.
  • 3
First Prev 3 of 3
M
Electrical 93 5.0 No Injector Pulse
  • machinermac
  • Jul 26, 2026
Fox 5.0 Mustang Tech Aug 1, 2026
Willybill32
A
1987 5.0 speed density Foxbody crank no start
  • Alan2204
  • May 23, 2026
Fox 5.0 Mustang Tech May 30, 2026
Mcmahst
  • brandyn200
  • Jun 20, 2026
AeroCoupe
  • dan50
  • Jul 18, 2026
dan50
  • Mindseye007
  • Aug 16, 2026
Mindseye007
