Calling ALL Tri-y owners
Don't need pics to tell you I've got right about a quarter inch each side between the header tube and shock tower and the engine seems to sit a bit to the passenger side. The drivers side has a dent in it from the pitman arm and right turns, so clearance there is a negative. This with early 65 motor mounts.
No there talking about once you install them your pitman arm dents the header tube because of clearence. And yeah hiting them will mess up your ceramic coating. Iv heard you can slove them problem with install 66 or 67 motor mounts. It sits the engine higher in the bay.
