  • 1994 - 1995 Specific Tech
cam break in not required?
  • Thread starter Thread starter mootang
  • Start date Start date Dec 13, 2004
mootang
907
texas
Dec 13, 2004
  • Dec 13, 2004
I ordered a trick flow stage 1 cam and it didn't come with break in instructions so I called trick flow and they said that hydrolic roller cams doen't require any break in at all. I've never heard of this, Is it true. also what assembly lube should I use?
Dan95-5.0
1,110
Manitoba, Canada
Dec 13, 2004
  • Dec 13, 2004
yes its true, trickflow is correct that you dont have to break it in cause its a roller cam.
i've used comp cams cam lube. pretty good stuff. if the cam's new it should of came with some.
blksn955.o
3,263
st.louis mo 314
Dec 13, 2004
  • Dec 13, 2004
My TFS1 didnt come with any lube, I did however use STP engine treatment, it is realy thick and sticks to parts well. My buds and I have used this always when installing/building stuff. We asked several engine builders in the erea and they all said that it would work fine and one even said that it is what he uses instead of assem. lube. It is realy,realy thick stuff that is like honey only thicker.
SOLD Trick Flow Box R Series Upper Intake w/90 mm Inlet
  • Habu135
  • Apr 30, 2026
  • Engine and Power Adder
Engine and Power Adder Aug 19, 2026
Habu135
Oil choice for after break in period.
  • Sask84gt
  • Feb 28, 2026
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 14, 2026
Praetorious
P
Surging/stalling! problem or tune?
  • djj62478
  • Oct 4, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 14, 2026
KRUISR
H
Ongoing Battle With Hydraulic Lifters
  • hailer06
  • Jun 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 9, 2026
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
