Cam combo
  • Thread starter Thread starter BullittStangV8
  • Start date Start date Jan 19, 2004
First Prev 2 of 2
Blown4.6
351
Orlando, FL
Jan 21, 2004
#21
  • Jan 21, 2004
  • #21
You're getting a lot of pretty good but confusing information here. I've built a bunch of motors and consider mystelf to be a bit of a cam expert (self titled)
First- the sound you want isn't "loop" it "lope" (just don't want you to do too much talking about "loop" Lope is the sound the engine makes as it begins to stall due to poor signal at the carb (usually caused by overlap and/or very tall valve lift while at low RPM)
Second- Your cam is 218 intake and 218 exhaust @.050. This is a mild cam. Not an RV cam, but mild and builds hp to 4500 rpm. YOu want one that builds to 5500-6000.
Third- with a stock converter, I think the Comp XE274 may be a little too lumpy for a stock converter. That cam (even with the fast intake ramps) has just a little too much duration. You could do it, and it would sound nice, but you'll sacrifice some down low. It's up to you. It would sound really nice. The XE268 is 226/230 @.050. This cam won't lope too much unless you idle at 600 rpm due to the ramp rates. This cam is really nice in terms of some lope, good low-end torque, nice cylinder pressure and vacuum. I have this cam in my very built 327 corvette and it pulls to 6000 rpm. I'll attach a sound / video file so you can decide if this is a good sound for you.
65 Stingray w/ EX268 and hp manifolds:
http://www.corvetteforum.net/classics/maximillian/corvette_web.wmv
Also, just keep in mind that you don't want to go further than 230 degrees MAX duration on the intake @.050. with your compression ratio and stall converter. As for "ping" it's not an issue unless you are 10.5:1 or higher with iron heads. As for lift, keep it under .5" and you'll be fine.
PoliceInterceptor
Keeper Of Automotive Oddities
2,161
Live in GA, But could be any where really.
Jan 21, 2004
#22
  • Jan 21, 2004
  • #22
Third- with a stock converter, I think the Comp XE274 may be a little too lumpy for a stock converter. That cam (even with the fast intake ramps) has just a little too much duration. You could do it, and it would sound nice, but you'll sacrifice some down low. It's up to you. It would sound really nice. The XE268 is 226/230 @.050. This cam won't lope too much unless you idle at 600 rpm due to the ramp rates. This cam is really nice in terms of some lope, good low-end torque, nice cylinder pressure and vacuum. I have this cam in my very built 327 corvette and it pulls to 6000 rpm. I'll attach a sound / video file so you can decide if this is a good sound for you..
He said his car is a manual. So, since it doesn't have a converter, he doesn't have to worry about it.
2 things:
Without doing all the math, a .30 327 is about 40-50 cubic inches bigger than a 289 so the 289 may idle slightly worse.
Those off brand motors have a much higher exhaust flow to intake ratio. What works in a 327 won't neccecarily work that well in a SBF.
Comp will tell you not to run the XE at much over 9.5:1 in an iron head motor.
I still think the Crane is a better choice, but thats me.
BullittStangV8
1,104
NJ
Jan 21, 2004
#23
  • Jan 21, 2004
  • #23
thanks for all the info guys. its allot to take in and try to understand. seems like not nowing the pistons that i have is a real problem. But i did find out some more info about the engine, here ya go:
Machine shop labor to rebuild cylinder heads: Hottank, glassbead, mangaflux, resurface, cut valves and seats, check valve guides, install seals, set spring heights, assemble and vacuum test. machine for 2.02/1.5 valves. machine for springs and seals. Manley stainless intake and exaust valves. Comp. retainers, Compe keepers, Valve stem seals viton.
Also the engine was freshened up a little evidently when the heads came off. The more i dig into this cars history the more little things im finding out about for performance changes. the only performance parts that ive added were the hooker headers and flowmaster exaust, Holley Street deamon, racing clutch disk, a new pressure plate, new flywheel, and change the normal wear and tear parts. (sparkplugs, oil, coolant, ect..)
I dont know if the added information about the heads affects any of this for the cam choice? anyone? keep helping me out, im learning a ton, and im hopefully getting closer to getting the right cam.
Mike
PoliceInterceptor
2,161
Jan 21, 2004
#24
  • Jan 21, 2004
  • #24
The valve sizes make me more concerned about the P/Valve clearance. Other than that I'm still on the Crane side of the fence.
Keep digging, the more you can find out the better quality of reccomendation we (and the cam companies) can give you.
BullittStangV8
1,104
NJ
Jan 21, 2004
#25
  • Jan 21, 2004
  • #25
what happens if there are problems with P/valve clearance?what would have to be done to fix it if the new cam caused contact?
Mike
Edbert
3,548
32
109
Austin TX
Jan 21, 2004
#26
  • Jan 21, 2004
  • #26
There's not been enough talk of heads/ports/valves. Each of these being stock or being changed will DRASTICALLY affect what would otherwise be the "right" cam for the job. If the heads and valvetrain is completely stock then I think the cam he has is not that bad, on the smallish size yes, but not "too small". Put some AFR205s on there and he's WAY undercammed.
BULLETSTANGV8...what kind of heads and valvetrain do you have now and what are you prepared to do or intending to use long term?
BullittStangV8
1,104
NJ
Jan 21, 2004
#27
  • Jan 21, 2004
  • #27
Edbert i have stock heads. the rebuild that they got was posted above. intake side of it is holley street deamon, edelbrock Rpm performer intake, stock heads, new pistons, (still need to find out the type/specs) hooker headers, flowmaster mid and after cat. top loader 4 speed with hurst shifter, 8 inch rear with stock gears.
As for intended use, its a weekend cruiser, and im trying to get it a little faster for those stop light showdowns. its not going to be a full on drag car, however it make make some passes down the 1/4 mile. Sadly allot of the specs on the engine were not passed on to me when i got the car. so im digging around on it, and putting the info together. thats how i came up with the specs on the cam, and i wanted to know if it was the right cam for my set up. if i could get a better cam that fits what i have and makes more hp and trq, i would be very very happy.
12sec67
1,301
San Diego, Ca
Jan 21, 2004
#28
  • Jan 21, 2004
  • #28
D.Hearne said:
Mine pulled all the way to 7500 and would have gone further, but the lifters wouldn't stay with the cam. Mine had Canfield heads and a B303 roller. Good thing the lifters started jumping, any more than 7500, and it probably would have shed a few rods.
a B303 roller cam has a lift of .480"/.480" and good for low end torqe and horsepower above 4000rpms. never seen a b cam rev that high but maybe you should get your tach checked out.
D
D.Hearne
11,730
south louisiana
Jan 21, 2004
#29
  • Jan 21, 2004
  • #29
Nothing wrong with my tach. The lift on this B303 is now .510, with 1.7 roller rockers. And with the breathing capabilities of the Canfield Heads and the Vic Jr. intake, it's not a problem to pull to 7500. You don't need a huge cam to rev that high, just a good set of heads.
Blown4.6
351
Orlando, FL
Jan 21, 2004
#30
  • Jan 21, 2004
  • #30
I somehow missed that. My bad. In that case, I'd go XE274 all the way. You don't really need much vac. (you don't have power accessories or A/C do you?) so, what the hell.
2 things:
True, but they are going to sit on the side of caution. They don't need the aggrevation. I'm running 10.5:1 exactly in the 327 Stingray. The heads are ported and polished cast iron. On crappy 91 octane fuel in California (where I live now) it doesn't make a sound.
Bottom line is that cam selection is an art for sure. Also, many things come into play. I just try to keep it simple. You could go into modified heads, single plane intake, lobe separation angle depending on the carb size......all these things will make the "perfect" choice a little different. A roller cam is always going to be better (and WAY more expensive and complicated to install). I just think you can't go wrong with the XE274 or XE268 kit from summit based on his objectives. Done and done.
D
D.Hearne
11,730
south louisiana
Jan 22, 2004
#31
  • Jan 22, 2004
  • #31
What's difficult about installing a roller cam? It sticks in the same as a flat-tappet and the lifters drop into their holes the same. Only difference is the all face the same direction and have either link bars between them or are held in place by a "spider" that's held down by two bolts. Actually a roller is in many ways easier than a flat-tappet to deal with for first timers. You don't have to worry about mixing the lifters up if you reuse them and there's no "break-in" for the cam, just fire it up and go.
brianj5600
1,964
Middle TN
Jan 22, 2004
#32
  • Jan 22, 2004
  • #32
Hr = $$$$
D
D.Hearne
11,730
south louisiana
Jan 22, 2004
#33
  • Jan 22, 2004
  • #33
Not if you start with a roller block. This evens out the playing field on cost.
PoliceInterceptor
2,161
Jan 22, 2004
#34
  • Jan 22, 2004
  • #34
Back on subject.....
Well,
Bullit, to answer your question. If there were piston to valve interference, you would have to either go to a smaller cam, of cut valve relief in the pistons. There are cutters that replace the valve and allow you to do this. Obviously, you have to pull the heads.
Since you do not know exactly what was done to the motor it makes this a lot harder. One would assume that a person who would have the heads cut for larger valves (2.02 intakes are much larger than stock) would also have ported them or had them ported. One would also think they would have used quality pistons and so forth. You may very well end up having to tear into the engine to figure it out. You might find that it is not even a 289…
One other thing that I would like to know is, what do you want the engine to do (or do better) that it does not do (or do well) now?
There are several things that you could do without changing the cam to help, such as replace the exhaust rockers with 1.7:1 ratio ones. On the other hand, you could change them all to 1.7:1 too. Replacing only the exhaust ones would give a very slight increase in exhaust duration (about 2 degrees) and a good bit more lift.
I think that we may have given you the idea that the High Energy 268 (what you have) is an awful cam. It is not. It certainly is not the best choice, and it is an old grind but it is good at doing what it was intended for which is to give improved performance, good sound, and every day drivability.
That said, it escapes me why anyone would put a single pattern cam (same intake and exhaust specs) in a Small Block Ford. With a few note able exceptions, every head out there can use more exhaust duration and lift than intake.
Keep trying to get more information about the motor. If you can see the front of the heads at the deck surface post a picture or describe lines cast into them at a right angle to the deck. Also look and see if there is a “GT” or any other identifying mark cast in near the head bolts on one end. See: http://www.stangpro.com/html/articles/gt40p_files/gt40p1.htm
You never know……………
BullittStangV8
1,104
NJ
Jan 22, 2004
#35
  • Jan 22, 2004
  • #35
ill post pics tonight after i get my camera working. i dont think i have GT40 heads.. but then again that would be a nice surprise.
Mike
Blown4.6
351
Orlando, FL
Jan 22, 2004
#36
  • Jan 22, 2004
  • #36
It doesn't just "go in" You need to modify a block built for a flat tap cam to accept a roller. Been there, done that. It's not that bad, but definately more work on top of the much more expensive kit.
First Prev 2 of 2
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Monday at 2:12 PM
mattcrp1
M
SBF Head Flow Table - Work in Progress
  • Noobz347
  • Sep 29, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 30, 2025
Specific Cam Questions that Google can't seem to answer...
  • ChillPhatCat
  • Jun 20, 2024
  • 2.3L (N/A & Turbo) Tech
2.3L (N/A & Turbo) Tech Jun 22, 2024
ChillPhatCat
Which one of these 3 intakes make the most sense for my 331 combo
  • from6to8
  • Jul 25, 2024
  • 1994 - 1995 Specific Tech
2K
1994 - 1995 Specific Tech Jul 26, 2024
AeroCoupe
I
289 cam break in help
  • iaff284
  • Aug 19, 2022
1965 - 1973 Classic Mustangs -General/Talk- Aug 19, 2022
iaff284
I
