Cam combo
  • Thread starter Thread starter 5.0stang_gt
  • Start date Start date Jan 10, 2006
5.0stang_gt
62
  • Jan 10, 2006
Im getting my heads fully worked on with a ported lower and the new jegs upper intake the problem is the rocker arms on my car are 1.7 and i dont want to take them off what cam could I use and this car is a street/strp car so I want a strong pull any suggestions.
bluevenom867
I will have images of molesting stuffed animals in
Dec 15, 2003
1,704
St.Petersburg,FL
Jan 10, 2006
  • Jan 10, 2006
Need more info.....
size of motor,compression,gearing,auto/stick,exhaust,what heads
Cant just go ask for a cam suggestion...
gt40_2003wes
I did sound a wee bit gay there.
Aug 14, 2005
461
ky
Jan 10, 2006
  • Jan 10, 2006
custom nuff said.
5.0stang_gt
62
  • Jan 10, 2006
basically stock motor with basic bolt ons but building the motor up. Im keeping the stock compression, 302 bottom end, headers, x pipe, dumps, auto, 3.73 gears.
5.0stang_gt
62
  • Jan 10, 2006
oh yeh the heads are stock for now.
bluevenom867
Dec 15, 2003
1,704
St.Petersburg,FL
Jan 10, 2006
  • Jan 10, 2006
Something like the Comp Cams, XE270HR Part#35-349-8.
5.0stang_gt
62
  • Jan 10, 2006
and this cam wouldnt cause the valve to hit the piston would it since it is the stock bottom end I dont want to notch the pistons or a custom cam.just something I can throw in.
bluevenom867
Dec 15, 2003
1,704
St.Petersburg,FL
Jan 10, 2006
  • Jan 10, 2006
I dont think you would have a problem with stock valve size.
Now if it were a 2.02 intake (whitch I dont know hwy you would put a 2.02 in the stock head),then I would be conserned,but not worried.Get were Im going?
It should work...
5.0stang_gt
62
  • Jan 10, 2006
ok because some guy told me that a stock engine can only have .512 lift I guess he didn't know what he was talking about and since the ratio difference the lift would come out to be .540 or something right. what is the stock ratio neway?
bluevenom867
Dec 15, 2003
1,704
St.Petersburg,FL
Jan 10, 2006
#10
  • Jan 10, 2006
  • #10
1.6 is stock ratio...
And peak lift doesnt mean anything,because the piston is near the bottom.It all has to do with the intake opening and closing (and the exhaust of course).
K
Engine Gt40p vs 180 procomp
  • Kleinjj27
  • Oct 27, 2026
Fox 5.0 Mustang Tech Nov 3, 2026
Kleinjj27
K
Strange timing issue
  • 92 Bimini Blue
  • Sep 26, 2026
Fox 5.0 Mustang Tech Oct 20, 2026
rednotch
Engine Hiccup at full throttle
  • keel
  • Jun 2, 2026
Fox 5.0 Mustang Tech Jul 30, 2026
keel
N
Looking for ECU/CHIP for 1992 5.0
  • Nathan26
  • Sep 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 8, 2026
Qtrhrse23
T
Oil burning on my recently buil 302
  • The blk67
  • May 15, 2026
Fox 5.0 Mustang Tech May 15, 2026
