Hi,
Very cool! Some of my older cars I’d like to get my hands back on, don’t think I’ll get that lucky, could retire off 2, a congratulations to you however. I’ll call Bullet, I’m curious now, lol! Congrat’s in your son graduating College!!
How many miles on the motor?
Have a flash tuning device?
Cool air intake & a 70mm T.body will wake it up. Note, LT Headers will require a tune due to different 02 sensor placement. Shorty’s will not, and will bolt up to the exhaust as the stock manifolds did. Will not yield results like long tubes, nor become loud(er).
In regards to Valvetrain, start out with the conventional single cam engine, it’ll yield broader exposure to more useful subject matter in less time, it’ll simplify a substantial SOHC/DOHC motor’s.
The approaches differ, theory stays solid. Will help flatten out that learning curve, as will this virtual engine building/Dyno program, click/download free trial(right price!). 7-10 days I believe.
Many base engines, can create- any displacement. LOTS of multiple major Mfg’s engine parts, ie, Heads, Cams, Intakes, bottom ends, Injectors, Carbs..Headers, etc.
All are infinitely variable by typing in any of your own values, even Flow-bench data.
Will allow you insight by viewing how the Dyno results are affected by modifications you make, can build any motor and correctly identify how a change affects it & why, program will tell you if it sees error within the build. Will optimize the build-if desired.
Every term is explained as you come across in great detail by clicking on it.
Tried it 20 years ago & was surprised then. I’ve bought every revision over the years, it’s right on track with builds I’ve done, parts used are there, results on Dyno, many within 5-10HP/10-12Ft/lbs. Now, with improvements over the years, it’s quite a useful tool...take a looksee..
https://engine-analyzer-pro.informer.com/3.9/
The springs & retainers for the 262AH will work fine for those Cams. Oe’s are likely spent, you want a solid 125lbs, valve seated. OE replacements would work, little light.
New Cam-New springs, keepers, retainers, Ford lifters (Lash adjusters in the OHC Valvetrain).. Viton valve seals.
A reputable shop will clean them, check for warpage, 3 angle valve job, reassemble, pressure test. Tool to compress springs is pricey, modded, large vise grips work (slot in top jaw for stem/keeper clearance). Or, have them pull valves, lap them at home.
If you haven’t yet seen the front covers off a 4.6/5.4 OHC motor, you’ll be surprised!
The timing chains are ridiculously long, first time I’d pulled one, looked like an accident waiting to happen..but work well..concept questionable, but well engineered.
With the cam info provided, timing events (in Crank degrees) will be similar, to slightly increased event duration over what the 262AH Cam uses.
(262AH Events)
Valve Timing @ 0.05" Lift:
Open .... Close
Intake: 4 BTDC 42 ABDC
Exhaust: 52 BBDC -2 ATDC
No, won’t be crazy. Will be a torquey Cam right on through, idle good, the reversion low, strong throttle response. 1,000-5 -5300 RPM’s. Events will tell the rest.
Sorry for the long dissertation..
Stay safe!
Best
-John
