Engine Cam install?
plumabob
12
I'm on Long Island NY. Thinking about a cam swap. What cams are recommended on a 4.6 2v forged supercharged engine? Like to get and idea on installation cost also. thanks
Hi,
What year SN95 is this?
The best NA Cams make the worst FI Cam’s, you want long duration Cams with no overlap. Were you already setup for FI or planning to go there with a fresh motor?
Helpful to get an idea of what your goals are and what the build is, CR, Supercharger selected, injector sizes, induction, exhaust, is this motor running head gaskets or is it O-ringed?
The OE PI Cams are examples of good FI Cams, yes- there’s better, an off the shelf set of new 2V 4.6l Cams are around 500-700$. If you want Custom grinds, add 250$.
That’s not including the extra odds & ends required for reassembly.
Best!
-John
