im installing a cam into my new shortblock tomorrow. its my first time installing one. i know its pretty straight forward but ive got a couple simple questions.
first, its a comp cams 274hr cam going into a 331 shortblock.
the peg on the front of the cam. i pulled it out of another comp cam my old sb had, and it fits almost perfect in the 274 but can slide in and out easily. the 274 came with two pegs. one is the same length and another shorter. it is a press fit i believe, ive tried tapping it gently a few times, it is straight but wont go. my question is, can i use the one that fits good but moves back and forth easily or try getting this other one in? there is no movement in the one that fits, perfect fit but it slides easily in and out.
second is, comp cams says you must install new hydraulic lifters. i still have the rollers i took out of my original 302 with unknown miles. they have NO wear pattern and are like brand new. is this really necessary? they have no damage, no wear pattern or anything like that. my pushrods are new hardened stock length comp cams.
i have assembly lube also. is there anything else key or any tips?
was worth it though.
