  • SN95 4.6L Mustang Tech
cam journal?
  • Thread starter Thread starter 98COBRA281
  • Start date Start date Jun 30, 2008
98COBRA281
1,348
30
59
Port St. Lucie, Florida
Jun 30, 2008
  • Jun 30, 2008
i noticed the front cam journal on my drivers side head had a little grove in it, you can barly feel it when you rub you finger over it, this is the best picture i could get of it, but can i use it how it is, or will i have to do somthing about itView attachment 312799
CobraRed_96_GT
1,421
UCSD/La Jolla
Jun 30, 2008
  • Jun 30, 2008
Not a good thing, an exact mate with the cam and cam tower cap are pretty important
98COBRA281
1,348
30
59
Jun 30, 2008
  • Jun 30, 2008
yeah i figured that, but its so small IDK if its a big deal
CobraRed_96_GT
1,421
UCSD/La Jolla
Jun 30, 2008
  • Jun 30, 2008
i've heard just using the wrong tower cap (like if the orig broke) could cause a problem, and that's with a perfect condition one. I'd ask an engine builder if i were you - i know i have a guy saved in my phone for this type of non-internet obtainable info based on experiance.
96SCstang
228
novi, MI
Jun 30, 2008
  • Jun 30, 2008
if it is really small then you will most likely be alright. i have put together countless 4.6l and some have had tiny grooves in the journals and are still running with no problems 2day. just make sure you use a hight quality assembly lube...alot of it...and tighten the cam journals in exact order to specified torque. you should be fine.
98COBRA281
1,348
30
59
Jun 30, 2008
  • Jun 30, 2008
thanks for the info, they are tiny, i put a little straight edge i have on it, the grove is so small its like not even there, maybe 1 or 2 thousands
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
A
Engine 04 GT timing chain issue
  • AwesomeX1103
  • Sep 3, 2025
SN95 4.6L Mustang Tech Nov 5, 2025
M
1996 GT Speedometer electrical nightmare
  • moon96gt
  • Oct 7, 2026
SN95 4.6L Mustang Tech Oct 17, 2026
CAMTWO1070
Fox won't crank over and fuel pump won't kick on.
  • djj62478
  • Jun 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 11, 2026
General karthief
Surging/stalling! problem or tune?
  • djj62478
  • Oct 4, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 14, 2026
KRUISR
