Nope. The stock rocker ratio is 1.6. Switching to roller rockers just frees up about 5HP from the reduced friction. If you bought some 1.7 Roller Rockers then your lift would change. I'd do the math but I just drank a 1/2 of a bottle of Shiraz (red wine) and I can't really think right now. To figure your your new lift do the following (1.7*.499)/1.6 and that should give you the amout of additional lift that you would see.
My 331 stroker dies if I floor it quickly it will build RPM's fine if I back off or slowly push down pedal?. 30lb, track heat intake ford F Cam Long tubes, trick flow heads etc.
I dont really know about my driveability issues yet i have only driven it around the city a little. Its a brand new motor and clutch so I cant rail on it yet.
