Cam lube required?
I have the 270 version of the same cam. Everyone I have talked to said to lube it real well. So I did. Please let me know how the 274 works for you; low end torque, mid range and top end. I was going to go with that cam but chose the 270 for cruising and drivability. Have not started the engine up yet but hopefully next month I can finish up the fuel system and let her rip.
68converted said:
I have the 270 version of the same cam. Have not started the engine up yet but hopefully next month I can finish up the fuel system and let her rip.
i have the 270 and love it:banana: :banana:
at idle, the car rocks as if it had a HUGH cam:D
my stall is a little low for getting off the line, but once the rpm get up a little she just hmmmmmmmmmmssssssssssss
D.Hearne said:
No lube necessary on a roller, but DO prelube the oiling system before firing it.
And no 20 minute @ 2000RPM to break the lifters in... one of the benefits of roller cams. I'd still like to err on the side of caution and make sure the cam, lifters, pushrods and rockers are well oiled before startup (see D.Hearne's advice). Soak the lifters overnight in clean motor oil.
Daniel
while roller cams require no special cam lube, it does require lubrication on the lobes and bearing surfaces. also regarding break in, i have a comp cam retrofit roller cam and they say that while there is no cam break in required, they do recommend running the engine at 1500 rpm for 20 min to make sure everything is well lubed before you let the engine idle.
