Cam Question
Ive been cam shoppin for a while and still can't make up my mind. its goin in the stang(mods in sig) but im not sure if the lift is too big. Its the Ford racing f-303 cam. specs below
Brand: Ford Racing Performance Parts
Product Line: Ford Racing Camshafts
Cam Style: Hydraulic roller tappet
Intake Duration at 050 inch LiftVL: 226
Exhaust Duration at 050 inch LiftVL: 226
Duration at 050 inch Lift: 226 int./226 exh.
Advertised Intake DurationVL: 288
Advertised Exhaust DurationVL: 288
Advertised Duration: 288 int./288 exh.
Intake Valve Lift with Factory Rocker Arm RatioVL: 0.512 in.
Exhaust Valve Lift with Factory Rocker Arm RatioVL: 0.512 in.
Valve Lift with Factory Rocker Arm Ratio: 0.512 int./0.512 exh. lift
Lobe Separation (degrees)VL: 109
Intake Valve Lash (in)VL: 0.000 in.
Exhaust Valve Lash (in)VL: 0.000 in.
Computer Controlled Compatible: No
Grind Number: M-6250-F303
im debating between this and the e-303 but ive heard the f-303 in a stang and it sounds bad ass! in the near future i plan to add nitrous so i dunno if that would be a factor. If anyone has any suggestions on this cam or if they have any other recommendations i would greatly appreciate it.
