Cam question.
88 Fox GT
1,674
Iowa
I just bought this really clean '88 GT last Friday. It came with a few extra parts like a set of Edelbrock valve covers. Well in the box that had the valve covers in it, I find this little slip of paper that has cam specs on it. Says it's a SBF hydraulic roller cam with the HO firing order, so I'm assuming that it's in the car. Valve lift is .498"/.498" and duration @ .050" is 220°/220°. Now, don't you think this cam would be decently noticeable? I mean when I first got it and listened to it idle I kind thought it had a little lump to it, but wasn't sure. I think the exhaust is stock, this would probably make it harder to notice. :shrug:
EDIT: Just thought of something. If this car is cammed, how well would the above specs work with speed density? Because the car runs and idles fine.
DMAN302 said:
Looks kind of like Ecam specs...if it runs ok leave it, nothing wrong with a few extra ponies in the car.
I never thought about taking it out, just curious on how noticeable this kind of cam would be. I am not even sure if it's in the car or not. lol
EDIT: Just looked up E303 cam specs and they are exactly the same. Looks like whoever bought the cam wanted a cheaper cam with the same specs as an E303. :shrug:
With stock heads and intake the cam will net you in the area of 10-15 HP for a stick..bit more if the heads and intake are upgraded. I would be looking to a MAF conversion before doing anymore moding in with the heads or intake.
