cam question
  • Thread starter Thread starter 91 HATCH
  • Start date Start date Aug 27, 2007
91 HATCH
Banned
May 17, 2007
262
illinois
Aug 27, 2007
  • Aug 27, 2007
Is there enough room for this cam with the 1.7 rockers on a stock 1993 motor or should i just use the 1.6 rockers
lift .480 w/1.6 rockers
lift .516 w/1.7 rockers
duration 220@ 0.50 intake
duration 226@ 0.50 exhaust
lobe seperation 112
ninety15.0
1,336
  • Aug 27, 2007
yup plenty of room...search around there are plenty of guys on this forum running 1.7's on stock motors!
88mouse
630
Mooresville nc
Aug 27, 2007
  • Aug 27, 2007
lobe seperation 112
Plenty of room. You really don't have to worry about PVC untill you get to around 540 lift and up.
cenok is family
1,409
69
79
Norman, Ok
Aug 27, 2007
  • Aug 27, 2007
looks like you're running a B cam? if so, i've seen tons of people running 1.7's with the B cam.
91 HATCH
Banned
May 17, 2007
262
illinois
Aug 27, 2007
  • Aug 27, 2007
The cam is a steeda #18 street/strip cam
5spd GT
"the 5.0 owns all"
9,516
Arkansas
Aug 27, 2007
  • Aug 27, 2007
Always a good idea to measure, but you should be okay...but no guarantees.
By the way, a piston is heading down the cylinder bore a good 2" when the cam lobe is at peak lift.
Duration, ramp rate, overlap, individual valve timing, etc, all play a roll in piston to valve clearance.
The stock cam peak lift of .444 could hit the piston if it is had a serious ramp rate and very early intake event or late exhaust events. Lift is the minimum to consider when seeing if p-v clearance problems will occur.
Adding more rocker arm (1.6 to 1.7) also slightly increases duration, maybe 1-2*
K
Engine Gt40p vs 180 procomp
  • Kleinjj27
  • Oct 27, 2026
Fox 5.0 Mustang Tech Nov 3, 2026
Kleinjj27
K
N
Looking for ECU/CHIP for 1992 5.0
  • Nathan26
  • Sep 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 8, 2026
Qtrhrse23
P
Cam spec
  • peter.farina
  • Oct 27, 2024
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 27, 2024
TOOLOW91
A
Discussion on mild budget build/ top end
  • Acesario
  • Feb 21, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 23, 2026
General karthief
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
