Cam Selection Help
Hey
I know there are about a million threads about cam selection help out there but I need a straight answer if you guys dont mind. I have an 89 mustand gt, 5-speed, trickflow upper and lower intake streetheat, 75 mm throttle body and spacer, 73 mm mass air flow sensor, 24 lb injectors, adjustable fuel regulator, ported and polished gt40 heads, recient rod and main bearings and rings, k and n filter, no smog equipment, equal length headers, 2.5 inch h pipe, msd 6al box, msd cap, rotor, wires, and blaster coil. Here is my problem, I have a ford racing f303 cam in it. I am not sure if that is the problem but it only ran 14.0 seconds at the track the other night. Before the heads it ran a best of 14.2. 12 degrees and 40 psi of fuel pressure w/o the line. I have reciently come to findout that it is a good supercharger cam not a n/a cam. I have heard that a B303 is a better choice. Any truth to that? HELP please. This thing should be running 12.50. what the hell.
thanks
2.0 and 2.1's, I know they should be down around 1.7. I am running Lake wood traction bars, 3.55 gears, and hoosher quick time pro's, a steeda short shifter, frame connectors and like I said the damn thing should run 12.5 all day long.
Even if the F isn't optimal, it should be much quicker. There are stock head/cam/intake cars that run mid-high 12's as I'm sure you know.
I'd try to find out WHY it's running the way it is before I went swapping the cam. Something is wrong. Did you degree the cam during install? Have you pulled the diagnostic codes out of the computer? Did you make all the changes at once -- did it ever run quicker with only some of the mods? Just curious if there were things you JUST changed, and then the performance went backwards on you. If so -- obviously, it's those mods you want to take a close look at.
If you didn't degree the cam -- then you don't know what the cam timing is -- and that being off can drastically impact performance.
Lastly - I'd think that cam with the other mods would like A LOT more ignition timing.
"...put the cam in straight up..." Did you use a degree wheel and a dial indicator? If not....then we don't know what the cam timing is - and that's potentially a big variable.
Rubber squeezed out of the damper? That might cause vibrations and the ignition timing to be WAY off - which could cause significant performance degradation.
