Cam specs
MY 85 GT
1,852
208
104
New Jersey
Does anyone know what the cam specs are on a 87 GT with speed density...VS the MAF cars i heard the cams were better maybe bigger on the speed density cars any truth to this?...Stock rockers are what 1.5's or 1.6's and if they were 1.5's going to 1.6's will help?...
Pretty sure they were the same. Stock rockers are 1.6, you can go to 1.7 if you wanted to add 0.030" lift at the valve.
Ok cool im going with the stock cam and a set of TF 170cc heads and TF 1.6 roller rockers and a TF street heat intake,bbk 70mm TB,On3 turbo kit 70mm..looking for 8-10 psi...stock short block...I think the cam should work well...I have an AOD with 3.55's i think the car should pull hard...
