Cam swap...what else should I do?
COramprat
...I can take it. I think.
Mar 2, 2003
8,474
1,463
223
Sea of Tranquility
I have the Comp XE262H cams sitting in my livingroom and have a couple of questions. My car has 133K miles on it. I did get a suggestion to replace the valve stem seals. I'm going to get new valve springs for the swap but what else would anyone suggest I do? I just want to maintain reliability...not really build up the engine other than cams right now. What should I look for when I pull the valve covers as far as problem areas?
Check the condition of the cam chain tensioners. With that many miles, the tensioners are bound to be worn. The guides are made of plastic. Just a thought...I did not have to replace mine @ 50,000 miles but you could see the obvious wear and tear.
