Cam Tool...
Redfire03GT
395
Newark, CA.
A while back, someone posted a link to a tool, used for sohc's, to..."lock" the cam gear in place. If I understood it's function properly.
If this makes any sense to anyone, and you can proovide a link of sorts, please do.
I'm attempting to get some cam's installed but, I don't want to pay an outrageous price.
Thanks in advance.
Thank you sir. Much appreciated.
Edit: Upon second look, can a stock GT make use of that? It says it's used for 2v motors equiped with removable cam gears. Once the valve covers are popped off, it becomes a gray area of knowledge for me.
Anyone happen to know for sure? Cause this tool would save me as **** load in installation costs.
The shop I'm bringing it to, says they'll have to remove the entire engine in order to change the cams. I'm looking for a way around that.
2001+ use removable/bolt on cam sprockets and spacers. 99/00 use press on sprockets. so, yes you could use it on an '03. However, it doesn't "lock" the cam gear in place - you still need to apply downward pressure on it while the cam is out of the car, but that's better than tearing the front of the motor down!
Jay
