  • SN95 4.6L Mustang Tech
cam ?
  • Thread starter Thread starter 96SCstang
  • Start date Start date Apr 4, 2007
96SCstang
228
novi, MI
Apr 4, 2007
  • Apr 4, 2007
alright, i know there are alot of cam threads out there, and believe me i just went through alot of them. But i couldnt find an exact answer so here we go. i am doing alot of mods on my car right now, and one of them is new cams. i have ported npi heads. now what cam is best for me. i want a pi cam, maybe something in the comp cam lineup or vt engines maybe. my ? is do i need new camshaft sprockets or will my stock ones work. i know i need the new bolt, and can it be done without taking the timing cover off? What cam do you guys rec. for a vortec s-trim, intercooler, pi intake, headers pushing around 12 psi boost? sorry for the long thread and thanks for any info you may have for me.:SNSign:
trailblazr81
571
Hollister, Cali
Apr 4, 2007
  • Apr 4, 2007
Well if your going with boost I'd say the VT stage 2 Blower cams. You should call/e-mail them for more info. http://www.vtengines.com/main.htm Once I get the green to make the scene I will be adding VT cams. And the installs Ive read show the timing cover off.
T
TGJ
1,049
  • Apr 4, 2007
What headwork was done on the NPI heads you have? NPI heads are limited to .550 lift unless the heads are modified to allow for more lift. That said, your car will do well with the Comp 268 or 274 Cam or you can look at Crower's NPI cams. Unless you do some modications to the heads, no VT cam will work.
J
Engine 4.6 Running rough at half throttle
  • jake411
  • Aug 3, 2026
SN95 4.6L Mustang Tech Oct 20, 2026
DangStitches
D
My next project , a 428 build!
  • horse sence
  • Jul 29, 2026
  • 9 10 11
4K
Classic Mustang Specific Tech Yesterday at 8:37 PM
K
Engine Gt40p vs 180 procomp
  • Kleinjj27
  • Oct 27, 2026
Fox 5.0 Mustang Tech Nov 3, 2026
Kleinjj27
K
Surging/stalling! problem or tune?
  • djj62478
  • Oct 4, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 14, 2026
KRUISR
Valve hitting piston?
  • krazedstang
  • Jun 9, 2025
SN95 4.6L Mustang Tech Jun 12, 2025
