Camber Plates For Coilovers
a91what
SendMeUrDataLog
10,739
6,720
214
Hillsborough county
After reading some information online recently about coil over installations I stopped and took a look at how mine were installed. Took my part numbers down and look things up I found out that the BBK camber caster plates on the car Are not recommended for coilovers and that some people have even had failures. I do not want this to happen to me while I'm driving Down the interstate. I guess what I'm looking for is a recommendation on a set of plates to use to replace the BBK set and anything else to look out for.
Do yo have the Grip BBK c/c plates?
If so I think it's the rubber bushings that makes them not compatible with c/o's.
I have a set of the Grip plates and was thinking of going c/o but read the same warning,
like posted above MM is probably your best bet.
I've only seen bearing style cc plates ran with coilovers. I've used UPR's on my daily driver with there coilover and front k member arm kit for the last six years no problems. I will be putting a set of there's on the coupe I'm building as well but I've had maximum motorsports on a previous car and they were nice to. having the two in hand I didn't really see where the extra cost between the two went honestly.
