Camber problems
  • Thread starter Thread starter afterglow
  • Start date Start date Jul 4, 2008
A
afterglow
89
  • Jul 4, 2008
I just got my car aligned but could not get it to spec. I was aiming for +2.5° caster, -0.5° camber and 1/8" total toe in.
I got everything to spec except for camber on the right side. The best we could get was -2.8°. My mechanic thinks it's a chassis alignment problem.
How do I get my alignment to spec?? The car a recent restomod '69 Mach 1. For the front end, I'm running CSRP Granada brakes, Opentracker roller perches, Opentracker street UCA, Moog LCA, KYB shocks, Shelby/Arning drop, power rack & pinion.
BarnStang
1,260
Hagerstown, MD
Jul 4, 2008
  • Jul 4, 2008
Are you sure its at MINUS 2.8? THat means the top of the tire is leaning inboard from center (straight up and down). If you are trying to GET to MINUS .05, it sounds like you need to shim the upper control arm to push the top of the tire outboard. If you can't get negitive camber on one side, it would mean the shock tower is leaning outboard? Keeping the upper control arm pushed out which would force the top of the tire outboard and produce positive camber. I may not completly understand the problem too...
Bosscat
1,265
England
Jul 5, 2008
  • Jul 5, 2008
My tires are wearing crazy on the inside, same issue as you are in. Still rebuilding the car, but I bought a Monte Carlo(sp) bar to widen the top of the shock tower up. The shock tower moved about 1/2" every little bit will help when shimming the upper control arm.
BarnStang
1,260
Hagerstown, MD
Jul 5, 2008
  • Jul 5, 2008
If you already have so many shims that you are running out of threads to have the nut hold the upper control arm, then the only thing you can do is to put the car on a rack and pull that shock tower out a bit. It must have been hit on that side at some point. THe other thing you can try is to knock the bolts out of the upper control arm and put longer ones in. It will make for a lot of shims though. If you change the bolts, make sure you get harnened bolts.
A
afterglow
89
  • Jul 5, 2008
I'll be doing the shim route first and will update you guys if that works. Just normal washers, right?? Or are there special magic Mustang washers??
Bosscat
1,265
England
Jul 5, 2008
  • Jul 5, 2008
Grind a slot in them so they can slip over the upper arm bolt, rather than taking the whole thing off
BarnStang
1,260
Hagerstown, MD
Jul 5, 2008
  • Jul 5, 2008
Your alignment shop should have shims???? For the A arms, it has a slot and a tab to hold it by, but yea, you can make your own. THe shims come in different thickneses to get the alignment right. You just may may not be able to get right on .05 with washers that are all the same thickness, but you can get pretty close.
A
afterglow
89
  • Jul 5, 2008
They should, but not here in the sticks (Philippines). Besides, they'll probably end up using washers as well so I might as well do it myself.
L
lauras70mach1
202
minnesota
Jul 7, 2008
  • Jul 7, 2008
Car Craft did a neat story on spiffing up your shock towers:
http://www.carcraft.com/techarticles/ccrp_0610_1967_ford_mustang_alignment_tricks/index.html
Fox Alignment Suggestions
  • PonyGTrider
  • Jul 12, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 13, 2025
PonyGTrider
Really Negative camber Shelby Drop on 70 mustang
  • Nick Bos
  • Sep 15, 2022
4K
1965 - 1973 Classic Mustangs -General/Talk- Oct 4, 2023
Nick Bos
Need suspension help? Check out OpenTracker
  • Husky44
  • Sep 9, 2021
2K
1965 - 1973 Classic Mustangs -General/Talk- Sep 9, 2021
Husky44
A
Suspension Question on Camber Kit for 1991 LX 5.0L
  • alchemist
  • Oct 12, 2019
Fox 5.0 Mustang Tech Oct 12, 2019
alchemist
A
A
Suspension Camber kit options for 91 GT
  • alchemist
  • Oct 12, 2019
alchemist
A
