Suspension Question on Camber Kit for 1991 LX 5.0L
alchemist
12
north carolina
Question from someone with little/no experience with a non-full framed car, but my alignment guy said I needed a 'camber kit' for the left side - he didn't have it at his shop but can do the camber adjustment later on. He was able to get toe in perfect, and caster. The final adjustment spec for camber for left side was -1.69 degrees (spec is -0.63 degrees). Which Moog kit would be preferred for this?
K100024 ?
K928 ?
K90476 ?
K80059 (camber wedge) ?
Thanks in advance!
  • Sponsors(?)
Thread starter Similar threads Forum Replies Date
H Suspension Alignment-Caster Camber Plate Question Fox 5.0 Mustang Tech 12
P Question On Lowering My 06 Gt And Caster Camber Plate... 2005 - 2014 S-197 Mustang -General/Talk- 3
ojgrape Camber Adjustment Questions SN95 4.6L Mustang Tech 2
E Camber Bolt Question... 2010 - 2014 Specific Tech 1
Dougsters Positive camber front wheel question ? Classic Mustang Specific Tech 2
Adam95GT Suspension Questions QA1 K member Stock Control Arms... Camber bolts? 1994 - 1995 Specific Tech 3
BLUMTL Caster/Camber question 2005 - 2009 Specific Tech 6
stprorolla49 Camber Question SN95 4.6L Mustang Tech 5
gnat Adjusted my caster&camber - questions + **pics** SN95 4.6L Mustang Tech 5
KENS89LX caster camber plate question Fox 5.0 Mustang Tech 1
DucatiRdr Caster/Camber plate install question Fox 5.0 Mustang Tech 4
gtcobra302 CASTER CAMBER PLATE QUESTION Fox 5.0 Mustang Tech 1
A Caster camber/suspension questions Fox 5.0 Mustang Tech 10
jaidedeye CAMBER PATE QUESTION Fox 5.0 Mustang Tech 4
C Question about Camber SN95 4.6L Mustang Tech 0
Silvr04GT Caster Camber Plates Question SN95 4.6L Mustang Tech 7
Scrody96GT Installing Pro3i caster camber plates (question) SN95 4.6L Mustang Tech 1
FrdMustangCpe Lowering Spring / Camber Plate Question Fox 5.0 Mustang Tech 3
0 Car Pulls a little to the left. Camber Question?? SN95 4.6L Mustang Tech 1
S Must. Adjust. Camber. Or. Die. (Adjustment Questions) Classic Mustang Specific Tech 11
Y Camber Caster Gauge Question SN95 4.6L Mustang Tech 0
Sonicstang0494 Question about calipers. 1996 - 2004 SN95 Mustang -General/Talk- 3
Waz900 Brakes Foxbody SN95 Booster install Question Fox 5.0 Mustang Tech 2
S 2002 v6 ECU Question SN95 V6 Mustang Tech 0
W 289 t5 questions 1965 - 1973 Classic Mustangs -General/Talk- 1
9 Engine HELP - Fuel Line to Fuel Rail Questions Fox 5.0 Mustang Tech 0
DarkFox Interior and Upholstery This might be a weird question... 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 5
A 93 mustang premium sound radio question 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 15
S Fuel Mass air identify question. Fox 5.0 Mustang Tech 9
L Transmission Question 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 15
Hoytster Wiring questions on new MS3X install Digital Self-tuning Forum 2
DarthBubbles 1988 LX 5.0 restoration questions 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 21
8 Coyote swap questions 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 37
A Gasket kit questions SN95 4.6L Mustang Tech 0
T MS3 Gold Box (87-93 Mustang) - IAC Valve Mode Question Digital Self-tuning Forum 4
4 1964.5 Coupe tail light question 1965 - 1973 Classic Mustangs -General/Talk- 3
R Passenger side leak issues and cowl questions 1996 - 2004 SN95 Mustang -General/Talk- 1
351crownvic Engine 95 5.0 replacing 93 5.0 questions Fox 5.0 Mustang Tech 8
V Early fox body dual exhaust conversion questions Fox 5.0 Mustang Tech 4
D 1997 Cobra (New Owner Questions) SVT Tech Forum 1
Old Catman EFI and megasquirt questions 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 14
o willingham T45 Transmission question 1996 - 2004 SN95 Mustang -General/Talk- 6
A Exhaust Question 2005 - 2014 Specific V6 Tech 9
My92cashtrap Engine Roller rocker question Fox 5.0 Mustang Tech 3
derek2079 I has question about my radiator temps 1965 - 1973 Classic Mustangs -General/Talk- 3
gearhead77 LED question 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 10
M New member, question about custom order times The Welcome Wagon 2
General karthief Fuel Purge canister question 1994 - 1995 Specific Tech 11
Red50Fox 88 Mustang GT 5 lug / disc conversion (almost done!) parking brake question 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 10
Old Catman Questions - Putting a 93 5.0 in a 66 1965 - 1973 Classic Mustangs -General/Talk- 2
