Camber problems
afterglow
89
I just got my car aligned but could not get it to spec. I was aiming for +2.5° caster, -0.5° camber and 1/8" total toe in.
I got everything to spec except for camber on the right side. The best we could get was -2.8°. My mechanic thinks it's a chassis alignment problem.
How do I get my alignment to spec?? The car a recent restomod '69 Mach 1. For the front end, I'm running CSRP Granada brakes, Opentracker roller perches, Opentracker street UCA, Moog LCA, KYB shocks, Shelby/Arning drop, power rack & pinion.
Are you sure its at MINUS 2.8? THat means the top of the tire is leaning inboard from center (straight up and down). If you are trying to GET to MINUS .05, it sounds like you need to shim the upper control arm to push the top of the tire outboard. If you can't get negitive camber on one side, it would mean the shock tower is leaning outboard? Keeping the upper control arm pushed out which would force the top of the tire outboard and produce positive camber. I may not completly understand the problem too...
My tires are wearing crazy on the inside, same issue as you are in. Still rebuilding the car, but I bought a Monte Carlo(sp) bar to widen the top of the shock tower up. The shock tower moved about 1/2" every little bit will help when shimming the upper control arm.
If you already have so many shims that you are running out of threads to have the nut hold the upper control arm, then the only thing you can do is to put the car on a rack and pull that shock tower out a bit. It must have been hit on that side at some point. THe other thing you can try is to knock the bolts out of the upper control arm and put longer ones in. It will make for a lot of shims though. If you change the bolts, make sure you get harnened bolts.
Your alignment shop should have shims???? For the A arms, it has a slot and a tab to hold it by, but yea, you can make your own. THe shims come in different thickneses to get the alignment right. You just may may not be able to get right on .05 with washers that are all the same thickness, but you can get pretty close.
