Hey Nick, or anyone with Cam swap experience.
As I mentioned in another post I'm planning on installing a set of Compcams XE270AH cams and new springs.
I'm still in need of a few mores pieces of info. Can anyone post a pic of the spring keepers, I need to understand what makes them to so hard to handle. I guess I could go down to the dealership and buy a set too. I'll need a few spares anyway right?? Also everyone mentions the keepers on top of the springs, I'm assuming not one is replacing the actual valve spring seats?? I'm guessing the head would have to be pulled to do that anyway??
Also Emissions is a concern, I could go with the base cam upgrade the XE262AH, but for the nearly $1000 investment of cams, springs plus a couple of new tools.(compersor, and chain tool) and 10 hours work. The base cam upgrade is not exceptable.
The guy at CompCams said that I would have trouble with emissions at idle because the ECU would have trouble at low engine rpm trying to keep the fuel/air just right, due to the eccentric cam. He said the car will crank and run, he said it would behave better at higher rpm, which is consistent with everyone comments about trouble with rough idle and stalling at low engine rpms. The CompCam guy recommend a Diablo chip to store a stock tune, a high performance tune, and "Lets just past Emissions tune".
Can someone give me guidance on their Chip/tune choice and if they were able to pass emissions. Also did you have to increase you idle rpm to keep the engine from stalling at stop lights??
