just want to check with you guys before I dive into this, A local place is charging me $2200 for Trick flow (street ) cams, valve springs, installation and dyno tuning..Does this sound about right ?? This is within my budget range...
Maybe a little better than 15-20HP...you could see 30 with the tune but that expense is pretty high. I've never advocated cam swaps in these cars unless you are a do it yourselfer. You'd be better off...and a lot happier...saving another 2 grand and having a supercharger installed.
i'd be careful with those trickflow cam's they have a high lift and are designed to work with the trickflow heads. if your going with stage 1's i think you will be okay but im not sure if the stage 2's will work because they have a .580 lift.
