I know you guys love the camshaft question, so here goes.
I picked up a 94 GT 5-speed back in November knowing that it probably needed a rebuild. I hadn't planned on doing the bottom end this year. Initially the plan was to make the car reliable and to upgrade the top end. I purchased SVE heads, 1.6 rockers, E303 cam, and Cobra upper and lower intake manifold. The heads and Cobra intake manifolds are all being ported.
Full disclosure, this is all being done at at shop. I don't have the time, space, experience, nor tools to take on such a project by myself. Bolt-ons I can handle, bottom end internals and machine work are not in my wheelhouse.
Now, after the top end was pulled, the machine shop advised that I go ahead and do a rebuild on the bottom end rather than waiting until next year.
It'll be more cost efficient in the long run, the mechanic said. And I had to agree. We have decided to just do a simple .030 over bore and install flat top pistons. The mechanic said that this would bump up the compression a bit to help the car get out of it's own way and still be a very streetable car without needing to worry about reliability. (If any of you guys have any experience with a similar build I'd love to hear what to expect from it.)
Anyway, my hang up is that the mechanic advised me to go with a X303 camshaft rather than the E303 that I already purchased. I did some noodling and saw that the X303 cam is meant to be at the strip more than around town. I have no intention of trying to set the world on fire with this car. My intention is to have a streetable, but stout Mustang in the garage that I will preserve and drive around town. This is not my daily driver.
With my setup and how I plan to use this car which cam should I go with E, B, or X? Or should I dodge the alphabet cams and go with some other brand that is more modern? I've seen on the forum that people often respond with, "get a custom grind." I'm fine with that but how much are we talking about for that? Is it worth the extra money for my setup? Who or which company should I contact for that? Please remember that I've already blown my budget for this year because I had no intention of rebuilding the bottom end this winter. $300 - $400 is the max I would want to spend. I'm open to all suggestions.
I also, plan to install a 4.10 in the rear this spring or summer. Currently it has the stock ring and pinion.
