camshaft break in
  • Thread starter Thread starter 67rcks
  • Start date Start date Jan 21, 2009
67rcks
373
Jan 21, 2009
  • Jan 21, 2009
As I was going through the posts discussing break in procedures it remains unclear what could cause flat tapped cam damage on a rebuild engine, assuming it has been properly lubricated with assembly lube, new mineral oil, has enough oil pressure and keep it rev at 3000 rpm for some 20 minutes. Any advise? Is it OK to break in in freezing weather? Is it recommended to use an oil treatment such as STP or so?
D
D.Hearne
11,730
south louisiana
Jan 21, 2009
  • Jan 21, 2009
I tried breaking in one of mine in 30* weather. It didn't turn out good. I figured the oil was too cold and kept that one lifter from getting set into motion by the cam lobe. Either that or that one lifter was machined wrong. No way of telling which it was. I'd wait for warmer weather or put it in a heated shop and allow the oil to warm up before trying to start it.
rbohm
6,698
550
204
tucson,az
Jan 21, 2009
  • Jan 21, 2009
i agree with waiting for warmer weather, unless you have a heated garage with some way to duct exhaust gases outside. as for using STP, i wouldnt use that, but i would use an oil treatment that had a large amount of zddp in the mix or use a racing oil for break in. zddp is used as an anti wear addivitve and is very good for cam break in with flat tappet cams.
R
RUSTYNUT
128
PDX
Jan 21, 2009
  • Jan 21, 2009
Royal purple I see is now making a break in oil. Any additive should be for break in use. Several out there. Also prime your oiling system before you start it up. It can take many precious seconds for oil to start getting around the engine. If you can't wait put a space heater near the pan for an hour or two to warm up. Or keep the oil in the house and warm in hot water, then put in car, pre- oil just before you start the car. Just don't get the heater to close to anything flamable.
Stripped Crank threads and cracked Crank Shaft Ring at end (what is it called?)
  • 69machmike
  • Nov 13, 2024
1965 - 1973 Classic Mustangs -General/Talk- Nov 19, 2024
89ripper
M
  • mnky99
  • Sep 5, 2025
mnky99
M
Progress Thread H/C Swap Problems/Ideas
  • sav22rem22
  • Mar 31, 2024
2K
Fox 5.0 Mustang Tech Sep 10, 2024
AeroCoupe
SN Mustang Magnum T56 swap
  • revhead347
  • May 24, 2024
  • 1994 - 1995 Specific Tech
7K
1994 - 1995 Specific Tech Jun 28, 2026
GearHeadGuy
Engine 90 GT 5.0 engine pull / rebuild questions
  • Justin87
  • Mar 18, 2019
2K
Fox 5.0 Mustang Tech Mar 22, 2019
Justin87
