  • 2005 - 2009 Specific Tech
Camshaft Positioning Issue
  • Thread starter Thread starter Nathan Chaney
  • Start date Start date Feb 7, 2017
N
Nathan Chaney
  • Feb 7, 2017
Hello I'm new to this forum but I'm hoping one of you may know what my issue is.
Last week my car was sputtering and cylinders 5 and 6 were misfiring then it just broke down. The Obd2 reader said it was the camshaft positioning sensor. I replaced it but the car will only start and sputter for a few seconds then shut right back off also the old sensor was all chewed up on the end. I can't quite figure out what else it could be. I also don't believe it's the alternator since I just replaced it about a month ago. If you have any ideas I'm open to anything.
R
racerraj
493
32
39
Dickson, TN
Feb 8, 2017
  • Feb 8, 2017
Did you make sure the new Cam sensor isn't chewed up on the end? Something had to eat the old one and it that problem wasn't fixed, it probably ate the new sensor.
N
Nathan Chaney
  • Feb 10, 2017
I was only able to get it started twice and for barely any time then I checked the sensor and no damage.
Red_LX
I’m not much help unless you’re looking for ****!
73
129
Morgantown, WV...where couches meet their doom
Feb 13, 2017
  • Feb 13, 2017
Probably need to pull your front cover and check the chain guides, unfortunately.
N
Nathan Chaney
  • Feb 15, 2017
I actually just did that last night and the drivers side seems good and tight (which is weird since that's the side the CPS was hit on) but the passenger side has nearly enough play to pull it all the way off the tooth. It doesn't look like the tensioner is putting any pressure on it.
N
Nathan Chaney
  • Feb 15, 2017
R
Red Pony
92
Chicago Area
May 8, 2017
  • May 8, 2017
Red_LX, how did you resolve this issue? Wondering if you timing chain jumped?
R
racerraj
493
32
39
Dickson, TN
May 11, 2017
  • May 11, 2017
If the tensioner lost tension, it could also be that the guides gave out. You probably want a timing chain set. Read directions carefully, everything has to be set just right when installing. Valve covers and front cover have to come off to get to them.
How many miles on the car?
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
G
Persistent P0102 and limp mode
  • Godless
  • Oct 30, 2025
2005 - 2009 Specific Tech Nov 11, 2025
Godless
G
L
1997 V6 Starting issue
  • leanzik04
  • Mar 20, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Mar 20, 2026
A
Check Engine codes jumping around
  • azactor
  • Jan 9, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 24, 2026
DadLife0724
M
85 mustang 5.0 cranking in run position
  • Mamaclean
  • May 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 1, 2026
General karthief
